| Keith914 |
May 29 2017, 08:24 AM
Member ![]() ![]() Group: Members Posts: 248 Joined: 29-April 16 From: Laguna Beach, California 92651 Member No.: 19,948 Region Association: Southern California |
What are the practical (including cost) options to change the ring and pinion gears to "lengthen" all the gears so as to optimize a more powerful engine?
| Mark Henry |
May 29 2017, 09:38 AM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
Most Porsche gearing changes are through the gears themselves, not the diff.
A good one for your app with a 901 is A, F, O, X and a flipped H gear in 5th spot. 915, 930, G50, etc can also be re-geared the same way but it gets spendy. Example custom Guards gear sets (pair/set makes one gear) for a 930 are $1200 per gear (set). |
Keith914 Ring and pinion gears. May 29 2017, 08:24 AM
Perry Kiehl IIRC there weren't options on R&P only gea... May 29 2017, 09:18 AM
forrestkhaag A one-day-newbie to gears with a more powerful en... May 29 2017, 09:33 AM
Mark Henry What is a more powerful engine? A /6? V8?
The 901... May 29 2017, 09:46 AM
forrestkhaag My early read is that it is as much an issue of th... May 29 2017, 09:52 AM
Steve AFAIK the 901 gear box only supports a 7:31 ring a... May 29 2017, 10:15 AM
Steve :bump:
For added Gear Calculator link in above po... May 29 2017, 12:11 PM
Dave_Darling If you have a 915 gearbox, there were a couple dif... May 29 2017, 12:30 PM
Chris914n6
The easier way to go is tires with a larger overa... May 29 2017, 04:00 PM
Montreal914 What about the 7:27 R&P from the Sportomatic?
... May 29 2017, 12:33 PM
Steve Wouldn't you want a higher ring & pinion t... May 29 2017, 01:35 PM
Montreal914
Wouldn't you want a higher ring & pinion ... May 29 2017, 02:07 PM
Steve
Wouldn't you want a higher ring & pinion... May 29 2017, 08:43 PM
Montreal914
[quote name='Montreal914' post='2490876' date='Ma... May 29 2017, 11:47 PM
Perry Kiehl I thought the '73 stock gearing worked pretty ... May 30 2017, 05:41 AM
Mark Henry A healthy 3.0 can start in 2nd no problem on every... May 30 2017, 05:56 AM
rick 918-S Don't forget that part of the cooling on an ai... May 30 2017, 06:26 AM
Mark Henry
Don't forget that part of the cooling on an a... May 30 2017, 10:33 AM
Steve Good point Rick. Even though my speedo says 80 mp... May 30 2017, 07:49 AM
Keith914 Thanks for all your responses. I hope to have my c... May 30 2017, 08:40 AM
Steve
Thanks for all your responses. I hope to have my ... May 30 2017, 08:51 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 08:15 AM |
