> Ring and pinion gears., Gear ratios.
Keith914
post May 29 2017, 08:24 AM
What are the practical (including cost) options to change the ring and pinion gears to "lengthen" all the gears so as to optimize a more powerful engine?
Steve
post May 29 2017, 10:15 AM
AFAIK the 901 gear box only supports a 7:31 ring and pinion. 2nd gear is fixed to the mainshaft, unless you swap it out for a 904 mainshaft, which is overly priced on ebay all the time. With the 904 mainshaft you could change all the gears to get where you want to be. There are tons of gear charts out there. If your worried about breaking first, I have seen some rare 911 4 speeds, that only use 2nd -5, but the gears are more optimized for a four speed. The v8 and 3.6 guys just start out in 2nd and run a flipped H for 5th.
When it comes to the overpriced and harder to shift 915 gear box, from 72-73? It has a 7:31 ring and pinion. From 74-86 it has a 8:31 ring and pinion. I'm running an 86 915 gear box with my 3.2. I only changed 5th to the highest 29:21 for over drive on the freeway.
With a 29:21 5th. I can do 80 mph at 3k RPM's.
Here is a link to a 901 gear calculator. If there is a virus in it and it blows up your computer or innocent animals suffer, you've been warned.
https://cisco.box.com/s/9iw994c3qanzdmij21evrr1bghd9uuhd
Keith914   Ring and pinion gears.   May 29 2017, 08:24 AM
Perry Kiehl   IIRC there weren't options on R&P only gea...   May 29 2017, 09:18 AM
forrestkhaag   A one-day-newbie to gears with a more powerful en...   May 29 2017, 09:33 AM
Mark Henry   Most Porsche gearing changes are through the gears...   May 29 2017, 09:38 AM
Mark Henry   What is a more powerful engine? A /6? V8? The 901...   May 29 2017, 09:46 AM
forrestkhaag   My early read is that it is as much an issue of th...   May 29 2017, 09:52 AM
Steve   AFAIK the 901 gear box only supports a 7:31 ring a...   May 29 2017, 10:15 AM
Steve   :bump: For added Gear Calculator link in above po...   May 29 2017, 12:11 PM
Dave_Darling   If you have a 915 gearbox, there were a couple dif...   May 29 2017, 12:30 PM
Chris914n6   The easier way to go is tires with a larger overa...   May 29 2017, 04:00 PM
Montreal914   What about the 7:27 R&P from the Sportomatic? ...   May 29 2017, 12:33 PM
Steve   Wouldn't you want a higher ring & pinion t...   May 29 2017, 01:35 PM
Montreal914   Wouldn't you want a higher ring & pinion ...   May 29 2017, 02:07 PM
Steve   Wouldn't you want a higher ring & pinion...   May 29 2017, 08:43 PM
Montreal914   [quote name='Montreal914' post='2490876' date='Ma...   May 29 2017, 11:47 PM
Perry Kiehl   I thought the '73 stock gearing worked pretty ...   May 30 2017, 05:41 AM
Mark Henry   A healthy 3.0 can start in 2nd no problem on every...   May 30 2017, 05:56 AM
rick 918-S   Don't forget that part of the cooling on an ai...   May 30 2017, 06:26 AM
Mark Henry   Don't forget that part of the cooling on an a...   May 30 2017, 10:33 AM
Steve   Good point Rick. Even though my speedo says 80 mp...   May 30 2017, 07:49 AM
Keith914   Thanks for all your responses. I hope to have my c...   May 30 2017, 08:40 AM
Steve   Thanks for all your responses. I hope to have my ...   May 30 2017, 08:51 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 08:10 AM
