| Keith914 |
May 29 2017, 08:24 AM
Member ![]() ![]() Group: Members Posts: 248 Joined: 29-April 16 From: Laguna Beach, California 92651 Member No.: 19,948 Region Association: Southern California |
What are the practical (including cost) options to change the ring and pinion gears to "lengthen" all the gears so as to optimize a more powerful engine?
| Dave_Darling |
May 29 2017, 12:30 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,335 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
If you have a 915 gearbox, there were a couple different R&Ps to choose from. The early ones had a 7:31 like our 901s do; the later had something like an 8:31?
The cost for a different R&P in a 901 box would be astronomical. And it would take time to find someone who could manufacture the gear set for you. The easier way to go is tires with a larger overall diameter. Most often done by going with larger-diameter wheels and not dropping the aspect ratio (sidewall height) of the tires to match. That effectively makes all of the gears taller. Or change over to a 915-based transmission. Or some other trans. --DD |
| Chris914n6 |
May 29 2017, 04:00 PM
Jackstands are my life. ![]() ![]() ![]() ![]() Group: Members Posts: 3,528 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
The easier way to go is tires with a larger overall diameter. Most often done by going with larger-diameter wheels and not dropping the aspect ratio (sidewall height) of the tires to match. That effectively makes all of the gears taller. --DD This. I stepped up to stock 205/55-16 Boxster wheels & tires. 2nd is machined into the shaft so can't do anything with it. As such changing first is near pointless, plus it sits on a smaller unsupported section of the shaft and snaps easily. I have a 3.0 so starting in 2nd is easy, and nice around town as I don't have to shift as much. 3 and 4 are good city gears. Flipped H 5th for highway cruising at 3000rpm. With the Boxster tires that's 90mph (IMG:style_emoticons/default/biggrin.gif) |
Keith914 Ring and pinion gears. May 29 2017, 08:24 AM
Perry Kiehl IIRC there weren't options on R&P only gea... May 29 2017, 09:18 AM
forrestkhaag A one-day-newbie to gears with a more powerful en... May 29 2017, 09:33 AM
Mark Henry Most Porsche gearing changes are through the gears... May 29 2017, 09:38 AM
Mark Henry What is a more powerful engine? A /6? V8?
The 901... May 29 2017, 09:46 AM
forrestkhaag My early read is that it is as much an issue of th... May 29 2017, 09:52 AM
Steve AFAIK the 901 gear box only supports a 7:31 ring a... May 29 2017, 10:15 AM
Steve :bump:
For added Gear Calculator link in above po... May 29 2017, 12:11 PM
Montreal914 What about the 7:27 R&P from the Sportomatic?
... May 29 2017, 12:33 PM
Steve Wouldn't you want a higher ring & pinion t... May 29 2017, 01:35 PM
Montreal914
Wouldn't you want a higher ring & pinion ... May 29 2017, 02:07 PM
Steve
Wouldn't you want a higher ring & pinion... May 29 2017, 08:43 PM
Montreal914
[quote name='Montreal914' post='2490876' date='Ma... May 29 2017, 11:47 PM
Perry Kiehl I thought the '73 stock gearing worked pretty ... May 30 2017, 05:41 AM
Mark Henry A healthy 3.0 can start in 2nd no problem on every... May 30 2017, 05:56 AM
rick 918-S Don't forget that part of the cooling on an ai... May 30 2017, 06:26 AM
Mark Henry
Don't forget that part of the cooling on an a... May 30 2017, 10:33 AM
Steve Good point Rick. Even though my speedo says 80 mp... May 30 2017, 07:49 AM
Keith914 Thanks for all your responses. I hope to have my c... May 30 2017, 08:40 AM
Steve
Thanks for all your responses. I hope to have my ... May 30 2017, 08:51 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 09:50 AM |
