FS Resored Front 15 MM Sway Bar $350 plus shipping, New Porsche bushings, Powder Coated Bar, New SS hardware, Zinc Plated parts |
bdstone914 |
May 29 2017, 07:58 AM
bdstone914 Group: Members Posts: 4,541 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Pictures to be added soon.
This is a very clean front sway bar I restored. You need the triangular mounts installed on the car to use this. Not included but available from several sources. The bar was powder coated semi gloss black. All other sway bar parts were stripped and zinc plated. New stainless steel bolts, nuts, lock washers and added load washers were added to prevent rusting. Genuine Porsche bushings were replaced in the drop links and sway bar triangular cups. Not pictured but included are SS bolts, washers, and lock washers that hold the sway bar triangular cups to the body. These are getting harder to find. $350 plus shipping. In the U.S. it will cost about $25 to ship. Bruce |
amfab |
May 30 2017, 08:10 PM
Member Group: Members Posts: 393 Joined: 17-May 16 From: Los Angeles Member No.: 20,004 Region Association: None |
Hi Bruce,
Is the factory 15 mm? Would this be a decent set up for mild street? I was looking to buying a 19mm Tarret. -Andrew |
bdstone914 |
May 30 2017, 09:00 PM
Hi Bruce, Is the factory 15 mm? Would this be a decent set up for mild street? I was looking to buying a 19mm Tarret. -Andrew Yes ,this is a stock bar. The Tarrett bar is great and has adjustability and stiffer settings. Do you have the sway bar mounts on the body and A arms? |
Lo-Fi Version | Time is now: 14th June 2024 - 07:18 AM |
