> 1.7 dies right after starting
averagejoe71
post Apr 3 2017, 01:02 AM
my 1.7 dies when it starts. Ill turn the key and it will shortly after stop and if i touch the pedal alittle within the small time frame it dies. Does anyone have any ideas of where to start checking to see whats the problem. All help is appreciated.
BeatNavy
post Jun 1 2017, 05:24 PM
Resistance. You need to check the following as a minimum:
1. CHT to ground at ambient temperature - check resistance from the lead to ground (e.g., negative battery terminal). Should be no more than 2.7K Ohms at today's ambient temps.
2. Make sure CHT is actually CONNECTED to the wiring harness. Inspect the connection and wiring to make sure it's not broken. The harness gets pretty beat up and nicked over 40+ years.
3. As a final check, if you're able, disconnect the ECU connector from the ECU and check resistance from pin 23 to ground. Should have same values as #1. There are 25 pins on the connector, so it's pretty easy to find pin 23.
You're MPS needs to be at least close to spec to work as well.
averagejoe71   1.7 dies right after starting   Apr 3 2017, 01:02 AM
BeatNavy   Fuel injection or carbs? If FI, first thing I wou...   Apr 3 2017, 03:08 AM
averagejoe71   Fuel injection or carbs? If FI, first thing I wo...   Apr 3 2017, 04:08 AM
Tbrown4x4   The CHT is near the #3 Intake port. I believe my ...   Apr 3 2017, 04:44 AM
averagejoe71   The CHT is near the #3 Intake port. I believe my ...   Apr 28 2017, 02:53 PM
mark04usa   The MPS may not be the cause of the engine to die ...   Apr 28 2017, 03:10 PM
averagejoe71   The MPS may not be the cause of the engine to die...   Apr 28 2017, 03:26 PM
BeatNavy   [quote name='mark04usa' post='2480525' date='Apr ...   Apr 28 2017, 04:01 PM
averagejoe71   [quote name='mark04usa' post='2480525' date='Apr...   Apr 28 2017, 04:28 PM
BeatNavy   Ok, now I'm clear. Then yes, get the Tangerin...   Apr 28 2017, 04:49 PM
averagejoe71   Ok, now I'm clear. Then yes, get the Tangeri...   Apr 28 2017, 05:03 PM
BeatNavy   I should add now is a good time as well to think a...   Apr 28 2017, 04:59 PM
averagejoe71   I should add now is a good time as well to think ...   Apr 28 2017, 05:07 PM
BeatNavy   [quote name='BeatNavy' post='2480574' date='Apr 2...   Apr 28 2017, 05:27 PM
averagejoe71   [quote name='BeatNavy' post='2480574' date='Apr ...   May 8 2017, 05:42 PM
BeatNavy   You can use your existing full load stop. That...   May 8 2017, 06:51 PM
averagejoe71   Sorry for the late update but I only replaced the ...   Jun 1 2017, 02:55 PM
BeatNavy   Likely more than one thing going on, which is not ...   Jun 1 2017, 03:55 PM
averagejoe71   Likely more than one thing going on, which is not...   Jun 1 2017, 04:54 PM
BeatNavy   Resistance. You need to check the following as a ...   Jun 1 2017, 05:24 PM
r_towle   You may be getting enough fuel from the cold start...   Jun 1 2017, 07:55 PM
averagejoe71   So good news. I found the problem. The red wire fo...   Jun 7 2017, 12:43 PM
BeatNavy   So good news. I found the problem. The red wire f...   Jun 7 2017, 03:59 PM
averagejoe71   So good news. I found the problem. The red wire ...   Jun 7 2017, 04:49 PM
The Cabinetmaker   So good news. I found the problem. The red wire f...   Jun 8 2017, 03:39 PM
BeatNavy   You are running full rich. I have not read this f...   Jun 8 2017, 03:48 PM
averagejoe71   So good news. I found the problem. The red wire ...   Jun 8 2017, 04:08 PM
euro911   Yes, Joe ... the port on the injector rail is wher...   Jun 7 2017, 06:23 PM
averagejoe71   Awesome I'll connect it to a gauge then. Is t...   Jun 7 2017, 11:19 PM
euro911   Awesome I'll connect it to a gauge then. Is th...   Jun 8 2017, 10:47 AM
averagejoe71   Awesome I'll connect it to a gauge then. Is t...   Jun 8 2017, 12:38 PM
BeatNavy   That's your Auxiliary Air Valve (AAR) or somet...   Jun 8 2017, 01:08 PM
averagejoe71   That's your Auxiliary Air Valve (AAR) or some...   Jun 8 2017, 03:17 PM
euro911   30 PSI is good. Pertronix units won't fail in...   Jun 8 2017, 03:40 PM
averagejoe71   30 PSI is good. Pertronix units won't fail i...   Jun 8 2017, 04:10 PM
The Cabinetmaker   Thanks Rob. His symptoms are indicative of a poorl...   Jun 8 2017, 03:59 PM
averagejoe71   Thanks Rob. His symptoms are indicative of a poor...   Jun 8 2017, 04:09 PM
Rand   He said he vacuum tested the MPS, but dang I st...   Jun 8 2017, 04:31 PM
averagejoe71   He said he vacuum tested the MPS, but dang I s...   Jun 8 2017, 05:01 PM
The Cabinetmaker   The adjustment knob is located on the top, drivers...   Jun 8 2017, 04:51 PM
averagejoe71   The adjustment knob is located on the top, driver...   Jun 8 2017, 05:04 PM
Rand   From post #1 of this thread, I thought it was alw...   Jun 8 2017, 05:05 PM
averagejoe71   From post #1 of this thread, I thought it was al...   Jun 8 2017, 05:13 PM
The Cabinetmaker   Unplug the mps BEFORE starting it!   Jun 8 2017, 05:48 PM
Rand   It's way rich!! I guess to ask my que...   Jun 8 2017, 05:51 PM
The Cabinetmaker   Like beat navy said on page one, you need a wide b...   Jun 8 2017, 07:23 PM
averagejoe71   Like beat navy said on page one, you need a wide ...   Jun 12 2017, 04:37 PM
Rand   Holy cow, if it runs that long with the MPS discon...   Jun 12 2017, 05:00 PM
averagejoe71   I hit another wall. I messed when putting in the n...   Jun 12 2017, 06:02 PM
914_teener   I hit another wall. I messed when putting in the ...   Jun 12 2017, 10:39 PM
914_teener   It just struck me looking at your picture is that ...   Jun 12 2017, 10:46 PM
averagejoe71   It just struck me looking at your picture is that...   Jun 12 2017, 11:14 PM
rhodyguy   Post the # on the MPS?   Jun 13 2017, 10:42 AM
Beach914   I've got a few. Depending on the number you ca...   Jun 14 2017, 07:57 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 08:16 PM
