> 1.7 doesn't want to stay running
Tbone425
post Jun 18 2017, 12:31 AM
So my 71 day for a few months. Went to start it and it started dumping gas at the injector elbows. I had to park it for a few months because I was in the middle of moving cross-country. Replaced the injectors and elbows as well as drained the fuel tank put a new filter. And fresh gas. Now it starts, wilnidke for a few seconds before dying. If gets gas it will choke and pop while the gas is pushed but then gets a little more run time. If I feather the gas quickly it will let the RPMs climb but continues piping and choking. I checked all of the vacuum lines and they seem to be fine, as well as the intake boot..no splits.
Thinking I would pull each injector and test it into a glass jar next. Any thoughts or ideas would be appreciated.
Thanks all!
BillC
post Jun 18 2017, 07:32 PM
QUOTE(Tbone425 @ Jun 18 2017, 02:31 AM) *
Thanks all!
Are the injectors the only thing you changed? And, what injectors did you get? Did you put on new seals with the new injectors?
If all you changed was the injectors, I'd start there. First, make sure you got the right injectors. Second, make sure the electrical plugs are connected properly to each one.
Finally, make sure the seals are seated and sealing properly. If the lower seals (the small ones) don't seal properly agains the manifolds, you'll get vacuum leaks. The upper seals need to be seated in the grooves of the injectors, so the hold-down clamps can push the lower seals into their seats.
- Lo-Fi Version Time is now: 1st July 2025 - 02:34 PM
