> OT - C++ question.
Jeff Krieger
post May 13 2003, 06:05 PM
Unregistered
Does anyone know how to modify this small program that I wrote in C++ so that for every cout statement there is a statement that writes the exact same information to the file accelfig.txt? I use this program to generate acceleration values and write them to accelfig.txt and then I read these acceleration values into another program that I wrote that numerically integrates these figures to calculate 0 to 60 mph and 1/4 mile times, speed at the end of the 1/4 mile, maximum hp, 60 mph to 0 braking distance etc. I use the free C++ compiler from http://www.bloodshed.net/dev/devcpp.html .
//CalcAccl1
#include < iostream.h >
#include < stdio.h >
// This program calculates 30 seconds worth of acceleration values, assumed
// to be in ft/s^2, and writes them to the file accelfig.txt.
main()
{ FILE *fp;
int counter;
double acceleration = 0, time = 0;
fp = fopen("accelfig.txt", "w");
for (counter = 0; counter <= 1600; counter++)
acceleration = time + 10;
fprintf(fp, "%20.10f\n", acceleration);
cout << "\nThe acceleration at " << time << " seconds is " << acceleration << '\n';
time = time + 0.0025;
for (counter = 1601; counter <= 4800; counter++)
acceleration = 14;
for (counter = 4801; counter <= 12000; counter++)
acceleration = 62 - 4*time;
fclose(fp);
Jeff Krieger
post May 14 2003, 12:21 AM
Unregistered
QUOTE(krk @ May 13 2003, 06:23 PM)
If you want to use ostream fiiles the same way you use cout, you have to do a few includes, and set the output stream up. Once set up, you use it just like cout, except it's heading to a file.
Or, if you want the mundane approach, you could always switch back to C. Oops, I see you have. :-)
#include
#include
#include
main()
   // open a file for outpout
   ofstream oFile("newoutput.txt", ios::out);
   // check to make sure it worked
   if ( !oFile ) { //open failed?
       cerr << "open failed" << endl;
       exit (-1);
   // write something to it
   oFile << "The horsepower at " << "etc" << endl;
   return 0;
This worked on GCC last time I tried it. (does it look familar? :-)
love kim.
Andy's way is much easier - besides, I just wanted to be able to write the output to a text file so I could check for errors more easily.
Are you Kim the lady mathematician? Hey, do you know why a negative ... ah forget it.
Jeff Krieger   OT - C++ question.   May 13 2003, 06:05 PM
SirAndy   here you go:   May 13 2003, 06:13 PM
Jeff Krieger   I get an error message when I try to open it with ...   May 13 2003, 06:16 PM
john rogers   I tried the code and it works fine as the data goe...   May 13 2003, 06:21 PM
SirAndy   all you need to do is to put this line in your cod...   May 13 2003, 06:22 PM
Brad Roberts   Went fine for me also.. Alfred... he wouldnt post...   May 13 2003, 06:23 PM
  May 13 2003, 07:42 PM
krk
  May 13 2003, 07:43 PM
krk   So the <>'s appear in quoted text to me, but n...   May 13 2003, 07:44 PM
  May 13 2003, 10:16 PM
- Lo-Fi Version Time is now: 28th September 2026 - 01:42 PM
