Holy Smoking' 914!, Help! |
Dck356 |
Jun 23 2017, 08:38 PM
Newbie Group: Members Posts: 20 Joined: 9-April 12 From: Davidson, NC Member No.: 14,355 Region Association: South East States |
Good evening gents. I've been lurking in the background while working on my 74 2.0L. Purchased the car almost a year ago from a member here who had it sitting as a project for about 12 years. So far I've done the following:
- removed gas tank and had it cleaned/sealed - replaced all fuel lines with the SS kit from Tangerine - replaced fuel pump and fuel filter - pulled distributor; had a bad pertronix unit - added points, condenser, rotor, cap, plug wires - popped the distributor back in and set static timing So this afternoon, after 12 years of not running, it fired right up. Exciting right? Not so much... the exhaust began producing a ridiculous amount of blue/white smoke - lucky the fire department didn't show. Seriously hoping that this is a timing problem and not a worn out engine. Tomorrow I'll check the dwell, put the timing light on it at 27 degrees... and say a little prayer to the Porsche gods. Any thoughts or words of advice? Thanks in advance!! |
Rand |
Jun 24 2017, 01:26 PM
Cross Member Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
Your timing is either WAY dangerously advanced now (be careful or you can damage things) or you have a MASSIVE vacuum leak. Or both. Since timing is what you futzed with last, you need to make sure you know it's right before chasing too many things at once.
Dck356 |
Jun 25 2017, 12:30 PM
Your timing is either WAY dangerously advanced now (be careful or you can damage things) or you have a MASSIVE vacuum leak. Or both. Since timing is what you futzed with last, you need to make sure you know it's right before chasing too many things at once. So I triple checked TDC today and the static timing is correct. But still, once I put the light on it and set to 27 degrees at 3500 rpms, the idle is at 3000 rpms! Got frustrated so pulled the distributor and noticed that the model number has been removed - so not sure that it's a 205A. I looked at prior post from the PO and at some point he said he purchased a rebuilt 205O distributor (type 311). If this is in fact the distributor that i'm using now - could that be my issue? Thanks for any help!! |
Lo-Fi Version | Time is now: 1st June 2024 - 12:33 PM |
