IS a perfect idle realistic with a 1.7 D-jetrinic?, Idle is low after hot restarts |
pmead |
Jun 25 2017, 03:45 PM
Newbie Group: Members Posts: 20 Joined: 5-February 17 From: Lewes Delaware Member No.: 20,813 Region Association: MidAtlantic Region |
Ok, I know its been discussed many times, and have searched the archives but I still have a small idle issue. Car is a 73 1.7 with stock injection. Car runs great, great mileage, runs cool, quiet, etc..... but after a hot start will idle slow (around 200-250) for about 2 miles of driving then returns to 950 and is great until I shut down for a few minutes and start it again. Then the idle will drop for a couple of miles again. I have tested every component and all components are in spec. (car does not have deaccel valve) Yesterday I replaced all vacuum lines, intake gaskets and sleeves injector seals etc.. I was hoping I had a phantom vacuum leak but car still does the same thing. The cold starts are fine. I have read that some people have spaced the cylinder head temp sender away from the head. Is this the cure????? By the way, timing, dwell, valve lash, compression are all correct. Am I expecting to much of the D-jet?? The car does not stall, but it does not seem correct and I like things to be correct. Any Ideas would be appreciated.
saigon71 |
Jun 26 2017, 01:28 PM
Advanced Member Group: Members Posts: 2,000 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
I run my idle slightly higher than recommended in the Haynes manual (about 1000-1050 RPM). This keeps my engine from stalling during the hot start condition you mentioned.
Unless I get stuck in stop & go traffic, the condition clears in a few minutes. So at this point, I'm just living with it. |
Lo-Fi Version | Time is now: 28th May 2024 - 06:45 PM |
