jcambo7 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,691 Joined: 24-December 08 From: Graham, WA Member No.: 9,867 Region Association: Pacific Northwest ![]() |
So after a little over three years I finally got some free time and money to get my 914 running again. Got her started up after changing oil, filter, and cleaning the gas tank. While I was trying to start it again after it quit running while I was tuning the carbs I found the ignition rotor to be fried and melted a bit.
Attached thumbnail(s) ![]() |
yeahmag |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,456 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California ![]() ![]() |
If you're using a high-performance coil, you need to dig the resister out of the epoxy. From there you will need to solder in a piece of stranded copper wire to take its place. I believe John at aircooled.net sell these premade.
michael7810 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,082 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region ![]() ![]() |
If you're using a high-performance coil, you need to dig the resister out of the epoxy. From there you will need to solder in a piece of stranded copper wire to take its place. I believe John at aircooled.net sell these premade. Thanks. I'll contact John and see what he has. I'm using an MSD Blaster coil |
Lo-Fi Version | Time is now: 2nd August 2025 - 01:41 AM |
