WTB: Plastic cover for targa latches (on padded roll bar) |
yeahmag |
Jun 26 2017, 11:55 AM
Advanced Member Group: Members Posts: 2,422 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
I'm after good, used plastic covers that hide the latch in the padded roll bar cover.
7TPorsh |
Jun 26 2017, 02:59 PM
7T Porsh Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California |
Never knew these existed...could use a nice pair...914rubber?
bdstone914 |
Jun 26 2017, 07:15 PM
bdstone914 Group: Members Posts: 4,529 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Mikey914 |
Jun 26 2017, 07:54 PM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Never knew these existed...could use a nice pair...914rubber? They do not make them. Yet. These will be available with the new roll bar. As well as the screw hole plugs that are already done. (IMG:style_emoticons/default/biggrin.gif) |
bdstone914 |
Jun 26 2017, 08:25 PM
Never knew these existed...could use a nice pair...914rubber? They do not make them. Yet. These will be available with the new roll bar. As well as the screw hole plugs that are already done. (IMG:style_emoticons/default/biggrin.gif) The early ones were zinc and look better. This is one I powder coated. This ones a little rough. The zinc emits gas when heated and can bubbles the paint. Attached thumbnail(s) |
BillC |
Jun 27 2017, 06:14 AM
Senior Member Group: Members Posts: 546 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region |
The early ones were zinc and look better. This is one I powder coated. This ones a little rough. The zinc emits gas when heated and can bubbles the paint. You may want to try baking them first, and then powder coating afterward (but before they completely cool off). Baking them first should cook out the gases, so the powder coat won't be affected when it's cooked. |
bdstone914 |
Jun 27 2017, 07:28 AM
The early ones were zinc and look better. This is one I powder coated. This ones a little rough. The zinc emits gas when heated and can bubbles the paint. You may want to try baking them first, and then powder coating afterward (but before they completely cool off). Baking them first should cook out the gases, so the powder coat won't be affected when it's cooked. Yes that works to a degree. And we bake, powder coated lightly , sand smooth and re powder coat |
Lo-Fi Version | Time is now: 31st May 2024 - 06:27 PM |
