> 75 still running rich, 75 still running rich
brooks944
post Jun 26 2017, 02:19 PM
My 75 is running rich and fouling plugs after just a few miles. One of the members spent several hours helping me check and figure out the FI a couple of years ago and that made a difference (both on the car and how much I value your experts here). I have 2 extra 'brains' is it time to change that and check? One is from a '75 and one from a 74, does that matter? Both are for a 1.8 which my car is. Fuel injectors are rebuilt as well as the cold start valve. Most vacuum hoses changed. Thanks for any input.
Rick
timothy_nd28
post Jun 27 2017, 05:51 PM
Hi Rick, I've been following this thread but too busy to put much thought into your issues. I'm preparing for the MCAT exam this week which has been nonstop studying.
Clark (Malcom2) will help walk you through, especially if you have any vacuum leaks.
Heed his advice and don't replace any parts until you have thoroughly tested them.
brooks944   75 still running rich   Jun 26 2017, 02:19 PM
Marty Yeoman   Check the pin count on the ECU. Some have six and ...   Jun 26 2017, 02:25 PM
jim_hoyland   Check the pin count on the ECU. Some have six and...   Jun 26 2017, 02:40 PM
brooks944   Not sure what that you mean, thanks for replying...   Jun 26 2017, 02:32 PM
brooks944   Probably a dumb reply, but do you have pics of wha...   Jun 26 2017, 02:38 PM
Marty Yeoman   Sorry My Bad. I meant AFM not ECU Check this out ...   Jun 26 2017, 02:46 PM
brooks944   Thanks, is the probable issue the AFM instead of t...   Jun 26 2017, 05:09 PM
malcolm2   So, did this just happen? Did something change, or...   Jun 26 2017, 05:56 PM
brooks944   The injectors were rebuilt a couple of years ago a...   Jun 27 2017, 08:31 AM
malcolm2   The injectors were rebuilt a couple of years ago ...   Jun 27 2017, 10:54 AM
brooks944   Also, the 75 has seven pins (I also have a 74 and ...   Jun 27 2017, 08:38 AM
malcolm2   Also, the 75 has seven pins (I also have a 74 and...   Jun 27 2017, 10:47 AM
white1975   cht sensor is bad I would say if the afm is not s...   Jun 27 2017, 11:02 AM
brooks944   Tim did help me check out the maf, it worked fine....   Jun 27 2017, 12:20 PM
malcolm2   Here is a simple test for you to try.... study up...   Jun 27 2017, 12:57 PM
brooks944   Here are some pictures of the spark plugs, probabl...   Jun 27 2017, 02:26 PM
Root_Werks   As some have stated, could be CHT, my money is on ...   Jun 27 2017, 03:15 PM
brooks944   Thanks, what do I need for a vacuum leak. Changed...   Jun 27 2017, 03:45 PM
malcolm2   Thanks, what do I need for a vacuum leak. Change...   Jun 27 2017, 03:55 PM
timothy_nd28   Hi Rick, I've been following this thread but ...   Jun 27 2017, 05:51 PM
N_Jay   My 75 is running rich and fouling plugs after jus...   Jun 27 2017, 06:39 PM
brooks944   Clark, I got 1.376k ohms when pin 13 was connected...   Jun 28 2017, 12:43 PM
malcolm2   Clark, I got 1.376k ohms when pin 13 was connecte...   Jun 28 2017, 02:29 PM
brooks944   Tim, good luck on your test and thanks for your he...   Jun 28 2017, 01:45 PM
malcolm2   if you can find a way to check your fuel pressu...   Jun 28 2017, 02:46 PM
malcolm2   Just had a thought.... when you pull the hoses on ...   Jun 28 2017, 02:59 PM
914_teener   I just use the screw tee hole on the driver side f...   Jun 28 2017, 07:16 PM
malcolm2   I just use the screw tee hole on the driver side ...   Jun 28 2017, 08:27 PM
brooks944   OK, got the HF fuel injector kit and measured pin ...   Jun 29 2017, 11:36 AM
malcolm2   OK, got the HF fuel injector kit and measured pin...   Jun 29 2017, 11:44 AM
brooks944   Also, I did change the ECU yet. I have what seems...   Jun 29 2017, 11:39 AM
brooks944   Thanks. Did not change the ECU yet. It did run s...   Jun 29 2017, 12:27 PM
brooks944   Here is a couple of pictures of the plug from cyli...   Jun 30 2017, 12:10 PM
malcolm2   So who has more ideas about running rich? All 4 c...   Jul 6 2017, 06:47 AM
Bartlett 914   So who has more ideas about running rich? All 4 ...   Jul 6 2017, 07:33 AM
- Lo-Fi Version Time is now: 6th June 2026 - 12:32 PM
