> Distributor ignition rotor fried, Anyone know why?
jcambo7
post Jun 26 2017, 05:15 PM
So after a little over three years I finally got some free time and money to get my 914 running again. Got her started up after changing oil, filter, and cleaning the gas tank. While I was trying to start it again after it quit running while I was tuning the carbs I found the ignition rotor to be fried and melted a bit.
porschetub
post Jun 26 2017, 11:43 PM
Looks like he is running a six,skipped MSD has not proved to be up there for dependable service,other opitions are out there.
Massive resistance @ that rotor,bad leads or fused points....who knows,don't understand why anyone runs points anymore...that's the bottom line.
Mark Henry
post Jun 27 2017, 09:20 PM
that's what I do!
QUOTE(porschetub @ Jun 27 2017, 01:43 AM) *
Sounds like you've been talking to guys using cheap ebay Chinese MSD clones. Sure a MSD can fail, but it doesn't happen often to the real deal. The old 6al is gold to the V8 crowd up here.
Nothing wrong with running a MSD with points, with a MSD the points become a simple low voltage on/off switch, they don't burn like on a stock system.
I've seen more pertronix failures than points failures. On the side of the road I can fix points with a screwdriver and a folded business card. Failed pertonix and yer done, call AAA.
I agree ditch the rev limiting rotor and use the MSD for rev limiting.
jcambo7   Distributor ignition rotor fried   Jun 26 2017, 05:15 PM
Dave_Darling   Heat melted it. (No s**t, Dave!) The heat is...   Jun 26 2017, 05:27 PM
jcambo7   Heat melted it. (No s**t, Dave!) The heat i...   Jun 26 2017, 05:42 PM
michael7810   The rotor in my car lasts about 8-10K miles before...   Jun 26 2017, 08:31 PM
yeahmag   If you're using a high-performance coil, you n...   Jun 26 2017, 09:02 PM
michael7810   If you're using a high-performance coil, you ...   Jun 26 2017, 09:52 PM
porschetub   Looks like he is running a six,skipped MSD has not...   Jun 26 2017, 11:43 PM
jcambo7   Looks like he is running a six,skipped MSD has no...   Jun 27 2017, 09:31 AM
Mark Henry   Looks like he is running a six,skipped MSD has no...   Jun 27 2017, 09:20 PM
'73-914kid   CB Perfomance sells a new rotor with just a brass ...   Jun 27 2017, 09:24 AM
michael7810   CB Perfomance sells a new rotor with just a brass...   Jun 27 2017, 02:22 PM
'73-914kid   Do you run an MSD box, or just the MSD coil with p...   Jun 27 2017, 10:11 AM
jcambo7   Do you run an MSD box, or just the MSD coil with ...   Jun 27 2017, 10:12 AM
yeahmag   Do you run an MSD box, or just the MSD coil with...   Jun 27 2017, 10:34 AM
sixnotfour   Have John get you e non rev rotor from worldpack   Jun 27 2017, 12:30 PM
jcambo7   Have John get you e non rev rotor from worldpack ...   Jun 27 2017, 12:31 PM
HarveyH   Do-it-yourself project: High Energy Rotor :welde...   Jun 28 2017, 04:04 PM
yeahmag   That's exactly how I did it before I switched ...   Jun 28 2017, 04:23 PM
jcambo7   Could this had fried the distributor also if I kep...   Jun 28 2017, 04:57 PM
'73-914kid   I would be very surprised to see any damage to the...   Jun 28 2017, 10:21 PM
jcambo7   I would be very surprised to see any damage to th...   Jun 29 2017, 10:40 AM
Mark Henry   Are you using a MSD or just a MSD coil? If just a...   Jun 29 2017, 11:33 AM
jcambo7   Are you using a MSD or just a MSD coil? If just ...   Jun 29 2017, 11:45 AM
Dave_Darling   Have you definitely confirmed that you are not get...   Jun 29 2017, 12:03 PM
jcambo7   Have you definitely confirmed that you are not ge...   Jun 29 2017, 12:14 PM
Mark Henry   [quote name='Dave_Darling' post='2501475' date='J...   Jun 29 2017, 12:20 PM
Mark Henry   Little ground strap, right side in pic, still atta...   Jun 29 2017, 12:05 PM
jcambo7   Little ground strap, right side in pic, still att...   Jun 29 2017, 12:12 PM
Mark Henry   Looks like a lot of corrosion on the dizzy cam lob...   Jun 29 2017, 12:17 PM
jcambo7   Looks like a lot of corrosion on the dizzy cam lo...   Jun 29 2017, 12:19 PM
craig downs   Where is your condenser? It is a little round part...   Jun 29 2017, 10:37 PM
jcambo7   Where is your condenser? It is a little round par...   Jul 4 2017, 05:42 PM
Mark Henry   Where is your condenser? MSD the points are ju...   Jul 4 2017, 08:03 PM
larryM   http://forums.pelicanparts.com/porsche-911...rpm-s...   Jul 5 2017, 11:38 AM
Perry Kiehl   Bingo!   Jul 4 2017, 06:01 PM
Perry Kiehl   I was mistaken, I missed the MSD part.   Jul 4 2017, 09:11 PM
- Lo-Fi Version Time is now: 2nd August 2025 - 01:39 AM
