914dave |
914 Addict ![]() ![]() ![]() Group: Members Posts: 724 Joined: 19-October 03 From: Willow Grove Pa. Member No.: 1,262 Region Association: North East States ![]() ![]() ![]() |
Won't be long til we're off to alignment and corner balance. The car is mostly street use and probably a monthly autocross. 21mm bars up front and 180# adjustable coilovers in the rear. 23mm front sway bar and the front spindles are raised 19mm. Torque bias limited slip and a stock rear sway bar.
Are you guys running stock settings? I don't mind a little more aggressive but it's not an all out competition car. I'll sacrifice a little more tire wear for performance. What have you guys run that works? |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
What do you guys think about doing your own alignments?
There's real cheap tools for setting camber or you could set up something that uses a tilt box. Toe in is easy to make a fixture to do that. I'm asking because I have 4 cars that will need alignment soon and I do at least 1-3 cars a year. The shops are all 60+ minute round trips, up to a couple hours there minimum, so by time I get back a better part of the day is shot. |
914_teener |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,266 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California ![]() |
What do you guys think about doing your own alignments? There's real cheap tools for setting camber or you could set up something that uses a tilt box. Toe in is easy to make a fixture to do that. I'm asking because I have 4 cars that will need alignment soon and I do at least 1-3 cars a year. The shops are all 60+ minute round trips, up to a couple hours there minimum, so by time I get back a better part of the day is shot. I do my own. As far as I can tell from having paid for it before, there is no difference except a lighter wallet. |
Lo-Fi Version | Time is now: 1st August 2025 - 04:58 AM |
