larger than 2 liter type 4 build. at what point do you start needing upgraded clutch?, will a standered sachs 2lier clutch work fine in a 2.7 lier type 4? |
funk |
Jun 28 2017, 11:41 PM
Member Group: Members Posts: 100 Joined: 23-June 14 From: sandpoint idaho Member No.: 17,531 Region Association: Pacific Northwest |
I am building either a 2.4 or a 2.7 type four and am wondering at what point do I start having to worry about needed something more than just the stock 2.0 liter type 4 sachs stock clutch? I know it probably depends on the cam and the amount headwork done but really can I get away with building a 2.7 with mild to fair amount of porting and abit larger valves? and obviously a sport cam. will I be seeing a lot of slippage? And Will something as simple as a particular plate help? thanks,Jo
Tom_T |
Jun 29 2017, 10:46 AM
TMI.... Group: Members Posts: 8,318 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California |
If it were me, I'd at least go to the 6-spring OEM Sachs clutch/TO Brgs/etc. as spec'd for the 914-6, over the stock 914/4 OEM clutch with 4 springs, since it's basically an easy plug-n-play upgrade to any 914.
(IMG:style_emoticons/default/beerchug.gif) Tom /////// |
Mark Henry |
Jun 29 2017, 11:28 AM
If it were me, I'd at least go to the 6-spring OEM Sachs clutch/TO Brgs/etc. as spec'd for the 914-6, over the stock 914/4 OEM clutch with 4 springs, since it's basically an easy plug-n-play upgrade to any 914. (IMG:style_emoticons/default/beerchug.gif) Tom /////// I agree, but can you even get the 4 spring anymore? (IMG:style_emoticons/default/confused24.gif) If your TO bearing is good you don't need a new one, there's a way to re-grease them if you have a press. |
Lo-Fi Version | Time is now: 7th June 2024 - 12:15 PM |
