> camber settings, What are you guys running?
914dave
post May 25 2017, 10:47 AM
914 Addict
Won't be long til we're off to alignment and corner balance. The car is mostly street use and probably a monthly autocross. 21mm bars up front and 180# adjustable coilovers in the rear. 23mm front sway bar and the front spindles are raised 19mm. Torque bias limited slip and a stock rear sway bar.
Are you guys running stock settings? I don't mind a little more aggressive but it's not an all out competition car. I'll sacrifice a little more tire wear for performance. What have you guys run that works?
HalfMoon
post Jun 26 2017, 10:55 AM
I've recently found a Porsche shop here in the Eastern Panhandle of WV that can do four wheel alignment and corner balancing and I've finally finished with most of my suspension and brake work (must replace atrocious spacers near future), so I'm wondering what recipe's the go fast crowd might suggest?
Dave and Chris, please chim in!
The stats:
V-8
Hankook Ventus V12 evo 225/50ZR16 front, 2.5” spacers (atrocious I know, thanks PO)
Koni red front
Stock sway bar front
Turbo tie rods
Fuzion ZRi 245/45R16 rear, 3” spacers (nutz, thanks PO)
Koni yellow with perches
220 springs
Stock sway bar rear
Boxed trailing arms
Rear chassis stiffening kit.
1986 911SC front hubs
Primarily street with no need for tire longevity, sometime track day car Summit Point WV
Additional info-Sheridan standard widebody. Quite a bit lighter than stock.
HalfMoon
post Jun 29 2017, 03:17 PM
QUOTE(HalfMoon @ Jun 26 2017, 12:55 PM) *
The stats:
V-8
Koni red front
Turbo tie rods
220 springs
Stock sway bar rear
Boxed trailing arms
Soooo, this is what Performance Automotive in Kearneysville, WV (just down the street from Summit Point Raceway) suggested.
Camber , Toe-in , Castor
Front L, -.94 , All 1/16 , 5 1/4
Front R, -.65
Rear L, -1.64
Rear R, -1.54
Corner weight-
Front 490 both
Rear 700 both
Stock Curb weight 2138
Mine (sbc) weight 2380
Keep in mind this isn't an exact science and when you take some here, you have to add some there, gain here, compromise there. Each car is unique. This was as good as they could get what they were shooting for without ALOT more modification in suspension adjustability.
Initial test drive seems like a different car. I can corner in excess of my ability. Track day tomorrow at the Point to see more and learn, learn, learn!
914dave   camber settings   May 25 2017, 10:47 AM
Dave_Darling   A starting point: -1.5 camber rear. -1.0 camber f...   May 25 2017, 02:26 PM
okieflyr   Dave, Do you have someone in mind to do the alignm...   May 25 2017, 04:24 PM
914dave   Dave, Do you have someone in mind to do the align...   May 25 2017, 04:27 PM
okieflyr   You might want to talk to Bill Sherwood @ CSE in O...   May 25 2017, 04:44 PM
914dave   I'm familiar with Bill, Dion has actually used...   May 26 2017, 04:15 AM
Racer Chris   I don't like to use more than 3/4 degree negat...   May 26 2017, 04:40 AM
914dave   I don't like to use more than 3/4 degree nega...   May 26 2017, 06:10 AM
HalfMoon   I've recently found a Porsche shop here in the...   Jun 26 2017, 10:55 AM
914dave   I've recently found a Porsche shop here in th...   Jun 26 2017, 11:24 AM
Racer Chris   ... Chris, please chim in! I would follow t...   Jun 26 2017, 11:55 AM
HalfMoon   ... Chris, please chim in! I would follow ...   Jun 26 2017, 01:27 PM
LowBridge   ... Chris, please chim in! I would follow ...   Jun 28 2017, 06:26 AM
HalfMoon   I've recently found a Porsche shop here in th...   Jun 29 2017, 03:17 PM
Dave_Darling   For a track car, the usual rule of thumb is ...   Jun 26 2017, 05:35 PM
HalfMoon   For a track car, the usual rule of thumb is ...   Jun 26 2017, 07:28 PM
plays with cars   For me the cars have always been driven on the str...   Jun 27 2017, 11:43 PM
Racer Chris   ... Depending on how many miles you'll be put...   Jun 28 2017, 07:08 AM
larryM   For me the cars have always been driven on the st...   Jun 28 2017, 03:20 PM
Mark Henry   What do you guys think about doing your own alignm...   Jun 28 2017, 07:29 AM
LowBridge   What do you guys think about doing your own align...   Jun 28 2017, 07:32 AM
Mark Henry   with even simply tools this is very easy to do.....   Jun 28 2017, 07:47 AM
Dave_Darling   Yep, I was thinking about that because my floor i...   Jun 28 2017, 12:32 PM
Mark Henry   [quote name='Mark Henry' post='2501101' date='Jun...   Jun 29 2017, 06:15 AM
914_teener   What do you guys think about doing your own align...   Jun 28 2017, 07:50 AM
Dave_Darling   I think you meant front toe-out to improve turn-in...   Jun 29 2017, 12:21 AM
jmitro   I think you meant front toe-out to improve turn-i...   Jun 29 2017, 06:00 AM
Dave_Darling   I have heard from folks on the Bird Board that the...   Jun 29 2017, 12:10 PM
Mark Henry   I have heard from folks on the Bird Board that th...   Jun 29 2017, 03:26 PM
Travis Neff   There's someone selling a real set of corner w...   Jun 29 2017, 03:34 PM
larryM   a chart in Porsche's 1972 Info for Sports Purp...   Jul 2 2017, 04:57 PM
HalfMoon   That above compilation was/is quite helpful inform...   Jul 2 2017, 08:01 PM
- Lo-Fi Version Time is now: 1st August 2025 - 04:40 AM
