| HalfMoon |
Jun 29 2017, 06:08 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 828 Joined: 13-November 12 From: Shenandoah Junction, WV Member No.: 15,144 Region Association: MidAtlantic Region |
So I know this has been talked to death thousands of times and when I do a google search there's reems of information, but rather than spend the entire evening reading through many posts that really aren't relevant, I thought I would pose the question and see what turns up.
Recently I had a four wheel alignment and corner balance done by a really great and well known shop out my way (who are very familiar with track cars for my local track-Summit Point) and when I asked the primary mechanic today what things he might suggest for my sbc Sheridan standard wide-body conversion, he said upgrading my rear brakes would be pretty important for that track. Soooo, yes there are lots of ways to go to be sure but I was wondering about retaining the standard rear 914 brake (and e-brake) but using the vented 911 SC rotor? Do I recall Eric made/makes a spacer for this or is/was that for converting 914 fronts to rears? A lil confused this particular application. I like the idea of retaining the stock 914 rear calipers if I can but I really want to go to vented rotor (as opposed to drilled). Thoughts? |
| HalfMoon |
Jun 29 2017, 10:10 PM
Spec for the rest
Hankook Ventus V12 evo 225/50ZR16 front Koni red front Stock sway bar front Turbo tie rods 911 SC rotors and calipers front Stock torsion bars (soon to be changed to 21's) Fuzion ZRi 245/45R16 rear Koni yellow with perches 220 springs Stock sway bar rear Boxed trailing arms Rear chassis stiffening kit. Porterfield all. |
HalfMoon Rear brake upgrade (again, lol) Jun 29 2017, 06:08 PM
Spoke I added spaced 914 rear calipers and 911 rear vent... Jun 29 2017, 07:30 PM
HalfMoon
I added spaced 914 rear calipers and 911 rear ven... Jun 29 2017, 09:22 PM
HalfMoon
I added spaced 914 rear calipers and 911 rear ven... Jun 29 2017, 09:30 PM
bdstone914 Makes me wonder if a spacer between the caliper an... Jun 29 2017, 09:51 PM
HalfMoon
Makes me wonder if a spacer between the caliper a... Jun 29 2017, 10:04 PM
Chris914n6
911 SC calipers and rotors on the front.
On the a... Jun 30 2017, 12:57 PM
Spoke Don't know why year the rotors are. I bought t... Jun 29 2017, 09:25 PM
HalfMoon
Don't know why year the rotors are. I bought ... Jun 29 2017, 09:30 PM
rgalla9146 Certainly '69 to '73 and surely later but ... Jun 29 2017, 09:35 PM
Spoke Here's a thread I started to ask vented rear r... Jun 29 2017, 10:39 PM
HalfMoon
Here's a thread I started to ask vented rear ... Jun 30 2017, 08:58 AM
Mark Henry I used spacers (flat washers) under my V-calipers ... Jun 30 2017, 10:00 AM
mgphoto I v'ed my rears about 5 years ago, I used the ... Jun 30 2017, 12:13 PM
Mikey914 The 6 vented calipers are always an option. I... Jun 30 2017, 12:44 PM
HalfMoon
The 6 vented calipers are always an option. I... Jun 30 2017, 06:34 PM
bdstone914
The 6 vented calipers are always an option. I... Jul 1 2017, 10:07 AM
HalfMoon
[quote name='HalfMoon' post='2501934' date='Jun 3... Jul 1 2017, 10:56 AM
Mark Henry
[quote name='HalfMoon' post='2501934' date='Jun 3... Jul 2 2017, 01:43 PM
[quote name='HalfMoon' post='2501934' date='Jun ... Jul 2 2017, 05:50 PM
Chris914n6
:agree: V-calipers use the 911 rotor. They also ... Jul 2 2017, 11:50 PM
:agree: V-calipers use the 911 rotor. They also... Jul 3 2017, 07:24 AM
mgphoto
:agree: V-calipers use the 911 rotor. They also... Jul 3 2017, 09:52 AM
Dave_Darling Ask the mechanic why he recommends upgraded rear b... Jun 30 2017, 04:57 PM
HalfMoon
Ask the mechanic why he recommends upgraded rear ... Jun 30 2017, 06:14 PM
Dave_Darling Cross-drilled are a waste of time for almost all c... Jun 30 2017, 09:10 PM
HalfMoon
Cross-drilled are a waste of time for almost all ... Jul 1 2017, 08:28 AM
HalfMoon Sooo, I reckon the Sebro 20mm will work allright
h... Jul 1 2017, 08:35 AM
mepstein On mine, i just shaved down the rotor diameter 2-3... Jul 1 2017, 08:43 AM
HalfMoon
On mine, i just shaved down the rotor diameter 2-... Jul 1 2017, 08:48 AM
On mine, i just shaved down the rotor diameter 2... Jul 1 2017, 08:57 AM
HalfMoon
[quote name='HalfMoon' post='2502077' date='Jul 1... Jul 1 2017, 09:04 AM
Mikey914 I have a 1 or 2 sets in the shop but haven't g... Jul 1 2017, 11:06 AM
mgphoto The bolts are the issue, I believe. Hardware is 7 ... Jul 1 2017, 06:07 PM
HalfMoon
The bolts are the issue, I believe. Hardware is 7... Jul 1 2017, 09:39 PM
914Sixer 914-6 GT cars had vented rotors. They were specia... Jul 2 2017, 06:34 PM
914-6 GT cars had vented rotors. They were speci... Jul 2 2017, 06:58 PM
mgphoto 901.352.041.12
Rear disc - 2
According to the 914... Jul 2 2017, 09:46 PM
larryM always a fascinating discussion
- must be 300 id... Jul 4 2017, 01:13 PM
- must be 300 i... Jul 4 2017, 01:40 PM
HalfMoon
[quote name='larryM' post='2502943' date='Jul 4 2... Jul 4 2017, 04:41 PM
HalfMoon
- must be 300 i... Jul 4 2017, 04:40 PM
HalfMoon Well crap.
I just realized the PO had converted th... Jul 5 2017, 04:45 PM
Well crap.
I just realized the PO had converted t... Jul 5 2017, 04:53 PM
Mark Henry
Well crap.
I just realized the PO had converted ... Jul 5 2017, 05:34 PM
HalfMoon Well the good news is that I was wrong!
Indeed... Jul 5 2017, 06:04 PM
pete-stevers Where is Erc??
:idea: Jul 5 2017, 07:44 PM
Mark Henry
Where is Erc??
:idea:
MIA Jul 6 2017, 08:00 AM
Racer Tricky part about Summit Point (main) is the T1 en... Jul 6 2017, 03:44 PM
HalfMoon
Tricky part about Summit Point (main) is the T1 e... Jul 6 2017, 03:58 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 05:12 PM |
