Type 4 Engine V-Belt Info |
McMark |
Jul 2 2017, 08:03 AM
I've always found that the V-Belts (alternator belt) that you get handed when you walk into a part store isn't quite right most times. So since I needed to find a shorter version for one of my high-amp alternator installs I figured now was a great time to finally do the research and find out what the RIGHT belt is.
Here's the final specs, which I'll update if more info comes to light: Belt Angle: 36° Belt Length: 965mm Top Width: 9.5mm My Selection based on the numbers is the ContiTech Brand. Actual installation experience to follow... And here's my methodology: First I grabbed an alternator pulley off the shelf and measured the V groove directly. This isn't particularly easy because the groove is so small, but I measured 34° (note there is a margin of error here). Belt length is farily easy based on a couple sources. The 914 PET didn't list a belt for the 4 cyl (that I could find) but I happened to have a car with a very original looking belt. VW logo and everything. It lists the length as 965mm. Also looking up the VW part number on that belt comes back with a 965mm belt length. I used a belt length calculator and entered measurements from a stock fan/alternator setup and also arrived at 960mm. Top Width is listed on my presumed-OE belt as 9.5mm. I had a 11mm top width belt here and it stands up out of the groove too much. What's Available Here's the belts I looked up for a 73 914 2.0, in a spreadsheet. I would love to add more listings to this file if you have any. Attached image(s) |
76-914 |
Jul 2 2017, 10:24 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,507 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Ahah! I wondered why I felt a ridge across the belt and the pulley itself. Good info, Mark! (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 1st June 2024 - 11:37 PM |
