| HalfMoon |
Jun 29 2017, 06:08 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 828 Joined: 13-November 12 From: Shenandoah Junction, WV Member No.: 15,144 Region Association: MidAtlantic Region |
So I know this has been talked to death thousands of times and when I do a google search there's reems of information, but rather than spend the entire evening reading through many posts that really aren't relevant, I thought I would pose the question and see what turns up.
Recently I had a four wheel alignment and corner balance done by a really great and well known shop out my way (who are very familiar with track cars for my local track-Summit Point) and when I asked the primary mechanic today what things he might suggest for my sbc Sheridan standard wide-body conversion, he said upgrading my rear brakes would be pretty important for that track. Soooo, yes there are lots of ways to go to be sure but I was wondering about retaining the standard rear 914 brake (and e-brake) but using the vented 911 SC rotor? Do I recall Eric made/makes a spacer for this or is/was that for converting 914 fronts to rears? A lil confused this particular application. I like the idea of retaining the stock 914 rear calipers if I can but I really want to go to vented rotor (as opposed to drilled). Thoughts? |
| Mikey914 |
Jun 30 2017, 12:44 PM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
The 6 vented calipers are always an option. I'll check to see if I have a set Eric did up for me.
| HalfMoon |
Jun 30 2017, 06:34 PM
| bdstone914 |
Jul 1 2017, 10:07 AM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,280 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
The 6 vented calipers are always an option. I'll check to see if I have a set Eric did up for me. I didn't see rear vented 6 rotors at PMB's site? Confused. 6's did not have vented rear rotors. They are 911 rotors. What calipers and rotors are used up front? That is where most of the braking happens. |
| Mark Henry |
Jul 2 2017, 01:43 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
The 6 vented calipers are always an option. I'll check to see if I have a set Eric did up for me. I didn't see rear vented 6 rotors at PMB's site? Confused. 6's did not have vented rear rotors. They are 911 rotors. What calipers and rotors are used up front? That is where most of the braking happens. (IMG:style_emoticons/default/agree.gif) V-calipers use the 911 rotor. They also must be cut down, at least they do on the /4 V-calipers. |
| Chris914n6 |
Jul 2 2017, 11:50 PM
Jackstands are my life. ![]() ![]() ![]() ![]() Group: Members Posts: 3,528 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
(IMG:style_emoticons/default/agree.gif) V-calipers use the 911 rotor. They also must be cut down, at least they do on the /4 V-calipers. Need to ask... what are the V calipers? Stock 914 rears or something else? |
HalfMoon Rear brake upgrade (again, lol) Jun 29 2017, 06:08 PM
Spoke I added spaced 914 rear calipers and 911 rear vent... Jun 29 2017, 07:30 PM
HalfMoon
I added spaced 914 rear calipers and 911 rear ven... Jun 29 2017, 09:22 PM
HalfMoon
I added spaced 914 rear calipers and 911 rear ven... Jun 29 2017, 09:30 PM
bdstone914 Makes me wonder if a spacer between the caliper an... Jun 29 2017, 09:51 PM
HalfMoon
Makes me wonder if a spacer between the caliper a... Jun 29 2017, 10:04 PM
Chris914n6
911 SC calipers and rotors on the front.
On the a... Jun 30 2017, 12:57 PM
Spoke Don't know why year the rotors are. I bought t... Jun 29 2017, 09:25 PM
HalfMoon
Don't know why year the rotors are. I bought ... Jun 29 2017, 09:30 PM
rgalla9146 Certainly '69 to '73 and surely later but ... Jun 29 2017, 09:35 PM
HalfMoon Spec for the rest
Hankook Ventus V12 evo 225/50ZR1... Jun 29 2017, 10:10 PM
Spoke Here's a thread I started to ask vented rear r... Jun 29 2017, 10:39 PM
HalfMoon
Here's a thread I started to ask vented rear ... Jun 30 2017, 08:58 AM
Mark Henry I used spacers (flat washers) under my V-calipers ... Jun 30 2017, 10:00 AM
mgphoto I v'ed my rears about 5 years ago, I used the ... Jun 30 2017, 12:13 PM
HalfMoon
[quote name='HalfMoon' post='2501934' date='Jun 3... Jul 1 2017, 10:56 AM
[quote name='HalfMoon' post='2501934' date='Jun ... Jul 2 2017, 05:50 PM
:agree: V-calipers use the 911 rotor. They also... Jul 3 2017, 07:24 AM
mgphoto
:agree: V-calipers use the 911 rotor. They also... Jul 3 2017, 09:52 AM
Dave_Darling Ask the mechanic why he recommends upgraded rear b... Jun 30 2017, 04:57 PM
HalfMoon
Ask the mechanic why he recommends upgraded rear ... Jun 30 2017, 06:14 PM
Dave_Darling Cross-drilled are a waste of time for almost all c... Jun 30 2017, 09:10 PM
HalfMoon
Cross-drilled are a waste of time for almost all ... Jul 1 2017, 08:28 AM
HalfMoon Sooo, I reckon the Sebro 20mm will work allright
h... Jul 1 2017, 08:35 AM
mepstein On mine, i just shaved down the rotor diameter 2-3... Jul 1 2017, 08:43 AM
HalfMoon
On mine, i just shaved down the rotor diameter 2-... Jul 1 2017, 08:48 AM
On mine, i just shaved down the rotor diameter 2... Jul 1 2017, 08:57 AM
HalfMoon
[quote name='HalfMoon' post='2502077' date='Jul 1... Jul 1 2017, 09:04 AM
Mikey914 I have a 1 or 2 sets in the shop but haven't g... Jul 1 2017, 11:06 AM
mgphoto The bolts are the issue, I believe. Hardware is 7 ... Jul 1 2017, 06:07 PM
HalfMoon
The bolts are the issue, I believe. Hardware is 7... Jul 1 2017, 09:39 PM
914Sixer 914-6 GT cars had vented rotors. They were specia... Jul 2 2017, 06:34 PM
914-6 GT cars had vented rotors. They were speci... Jul 2 2017, 06:58 PM
mgphoto 901.352.041.12
Rear disc - 2
According to the 914... Jul 2 2017, 09:46 PM
larryM always a fascinating discussion
- must be 300 id... Jul 4 2017, 01:13 PM
- must be 300 i... Jul 4 2017, 01:40 PM
HalfMoon
[quote name='larryM' post='2502943' date='Jul 4 2... Jul 4 2017, 04:41 PM
HalfMoon
- must be 300 i... Jul 4 2017, 04:40 PM
HalfMoon Well crap.
I just realized the PO had converted th... Jul 5 2017, 04:45 PM
Well crap.
I just realized the PO had converted t... Jul 5 2017, 04:53 PM
Mark Henry
Well crap.
I just realized the PO had converted ... Jul 5 2017, 05:34 PM
HalfMoon Well the good news is that I was wrong!
Indeed... Jul 5 2017, 06:04 PM
pete-stevers Where is Erc??
:idea: Jul 5 2017, 07:44 PM
Mark Henry
Where is Erc??
:idea:
MIA Jul 6 2017, 08:00 AM
Racer Tricky part about Summit Point (main) is the T1 en... Jul 6 2017, 03:44 PM
HalfMoon
Tricky part about Summit Point (main) is the T1 e... Jul 6 2017, 03:58 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 03:38 PM |
