Olympic 914 |
![]() ![]() ![]() Group: Members Posts: 1,745 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States ![]() ![]() |
The heater fan motor was pretty cruddy so I disassembled it and polished the armature and greased the ends then bench tested it and it ran pretty good. loosened the bolts on the housing and while it was running wiggled it around a bit until it ran the smoothest. when I reassembled it I noticed a clear plastic flapper inside the blower housing. No spring on it to hold it closed. When I put the fan in the car with the outlets pointed in what looked to be the best direction, pointing towards the pass side, the flapper valve hung open.
Looked at the "originality photos" and see that the outlet was installed to point straight up (?) in this position the flapper closes by gravity and would open whenever the fan is blowing. What does this flapper do ? |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,249 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
Outlets, plural? Are you using an early fan?
Olympic 914 |
Outlets, plural? Are you using an early fan? Original '73 fan with single outlet mounted in original location. but installed a dual outlet adapter from a later model (I believe) To hopefully increase the heat. Or maybe to keep the engine fan from pulling hot air out of the heat exchangers into the engine bay (IMG:style_emoticons/default/confused24.gif) This could be the answer. (IMG:style_emoticons/default/beerchug.gif) I did mount the housing so the flapper would be closed by gravity when the blower is not running. |
Lo-Fi Version | Time is now: 1st August 2025 - 02:14 PM |
