> Ignition switch questions - Update: It's ALIVE!, Cranks, but won't start.
ThinAir
post Jul 4 2017, 12:02 AM
Best friends
My 73 has developed an issue. It will crank, but will not start. When the key is turned to the start position, all the lights on the gauges go out and the needles go to the bottom. It is my understanding from the "Dr. 914" tip book that this indicates a bad ignition switch.
I've checked the switch with an ohm meter just to try and educate myself on what is happening. I see that in the on or start positions I have continuity from pin 30 to pins X and 50, but no other pins. I know that I have power in the harness to pin 30 so that means that when I try to start it these same pins are getting power. I'm wondering if this is the way the switch is supposed to function, or what pins should I expect to get power.
Assuming that the switch is functioning as it should, is there anything else (like a relay) that could cause this behavior?
Mark Henry
post Jul 4 2017, 01:07 PM
that's what I do!
(IMG:style_emoticons/default/agree.gif) with the majority of the time no spark.
You do have power to the coil right? I know stupid question but I have to ask....
- Lo-Fi Version Time is now: 18th March 2026 - 05:30 AM
