jcambo7 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,691 Joined: 24-December 08 From: Graham, WA Member No.: 9,867 Region Association: Pacific Northwest ![]() |
So after a little over three years I finally got some free time and money to get my 914 running again. Got her started up after changing oil, filter, and cleaning the gas tank. While I was trying to start it again after it quit running while I was tuning the carbs I found the ignition rotor to be fried and melted a bit.
Attached thumbnail(s) ![]() |
craig downs |
Senior Member ![]() ![]() ![]() Group: Members Posts: 769 Joined: 25-November 05 From: mira loma ca. Member No.: 5,189 Region Association: Southern California ![]() |
Where is your condenser? It is a little round part that is about 3/4 in diameter by 1" long that usually is attached to the outside of the distributor with a wire running to the points.
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
Where is your condenser? MSD the points are just a trigger, no condenser needed, no ballast needed. Points are only seeing milliamps, not enough to do that damage IMO. One thing I have heard of is the points can't burn away any oil mist, not a big issue in our engines, but you do have to keep an eye on dirt and grime. (IMG:http://www.914world.com/bbs2/uploads_offsite/forums.pelicanparts.com-26-1499220184.1.jpg) |
larryM |
emoze ![]() ![]() ![]() Group: Members Posts: 891 Joined: 1-January 03 From: mid- California Member No.: 65 Region Association: Northern California ![]() ![]() |
http://forums.pelicanparts.com/porsche-911...rpm-solved.html "Resistor-less rotors are a must, especially when the plug gaps get opened up to .040-.045 as they should. ______ Steve Weiner Rennsport Systems" **************************** fwiw - i ran MSD 6A & Blaster coil with pertronix-ignitor and 911 resistor-rpm-limited-rotor & stock 911 wire set (solid wires with suppressor at end) for about 15 yrs on both 2.8 & 2.7 with no failures such as displayed in O.P. note that MSD also recommend drilling holes in our smallish Bosch cap to relieve ozone buildup - tho i did not do that until the last couple yrs https://forums.msdperformance.com/forumdisp...ation-Questions **************************** Where is your condenser? MSD the points are just a trigger, no condenser needed, no ballast needed. Points are only seeing milliamps, not enough to do that damage IMO. |
Lo-Fi Version | Time is now: 2nd August 2025 - 01:41 AM |
