| TheWeatherMan |
Jul 5 2017, 12:45 PM
Newbie ![]() Group: Members Posts: 18 Joined: 2-July 17 From: Vienna, VA Member No.: 21,222 Region Association: MidAtlantic Region |
What modern EFI systems is everyone installing on their Type-IV engine?
| jd74914 |
Jul 5 2017, 01:31 PM
Its alive ![]() ![]() ![]() ![]() Group: Members Posts: 4,889 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
I'm putting a MS3X (Megasquirt) on my 2.0L. Non T-IV, but my 2.5LGT motor is getting a Syvecs S8.
May people have used MS1/2 and Microsquirt on with good success. They are really quite capable systems for the money, and far sophisticated enough to run a simple motor. The Microsquirt especially (not as much capability, but fully sealed with better connectors) is pretty well suited for this application. The $5k your mechanic quoted you for a MoTeC system could be quite the deal (wonder which ECU?), albeit expensive compared to an MS conversion, since the MoTeC hardware is pretty costly. As a note, getting everything starting/running well is really more a matter of good, thorough tuning than the ECU. |
TheWeatherMan What modern EFI is everybody using Jul 5 2017, 12:45 PM
jimkelly seems very few have moved away from stock FI, and ... Jul 5 2017, 02:52 PM
porschetub There was a guy a few years back that used GM ECU ... Jul 5 2017, 03:38 PM
914forme
There was a guy a few years back that used GM ECU... Jul 5 2017, 09:06 PM
Mark Henry I installed SDS way back in 2004, still running th... Jul 5 2017, 03:54 PM
JamesM PEFI alone adds no HP, but a proper tune on top of... Jul 5 2017, 07:12 PM
914_teener
PEFI alone adds no HP, but a proper tune on top o... Jul 5 2017, 07:42 PM
JamesM
So James.....just as an observer. What is the mi... Jul 6 2017, 01:30 AM
Mark Henry
PEFI alone adds no HP, but a proper tune on top o... Jul 5 2017, 08:19 PM
JamesM
Marketing Koolaid :D
3D tuning table? does t... Jul 6 2017, 01:54 AM
Mueller I would guess that there are 5 to 10+ 914s that ar... Jul 5 2017, 04:14 PM
wndsrfr I'm on SDS on the 2316 Raby kit engine that Dr... Jul 5 2017, 07:47 PM
Dtjaden Megasquirt MS3X full engine management (FI and ign... Jul 5 2017, 08:39 PM
falcor75 Who's going to tune your car? If you know that... Jul 5 2017, 10:30 PM
Mueller
[b]Who's going to tune your car? If you know ... Jul 6 2017, 12:31 AM
falcor75 Must have:
Crank position sensor
Throttle position... Jul 6 2017, 01:47 AM
JamesM
Must have:
Throttle positio... Jul 6 2017, 02:11 AM
falcor75
Must have:
Throttle positi... Jul 6 2017, 03:21 AM
jimkelly microsquirt diagram Jul 6 2017, 04:26 AM
ottox914 SDS. See my sig below for the install thread. It... Jul 6 2017, 06:08 AM
Mark Henry :agree:
I sold Dave his SDS system.
SDS is hand... Jul 6 2017, 07:35 AM
Mark Henry A member asked me if he should ditch his homebuilt... Jul 6 2017, 11:52 AM
90quattrocoupe Now before I start this post, I am not in anyway a... Jul 6 2017, 12:40 PM
Mark Henry That's one of the issues with many PEFI system... Jul 7 2017, 09:51 AM
TheWeatherMan Thanks, ill continue to research the SDS set up an... Jul 7 2017, 10:37 AM
Mark Henry
Thanks, ill continue to research the SDS set up a... Jul 7 2017, 11:38 AM![]() ![]() |
Lo-Fi Version | Time is now: 17th September 2026 - 06:12 AM |
