| db9146 |
Jul 4 2017, 08:52 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 953 Joined: 21-December 04 From: Atlanta, GA Member No.: 3,315 Region Association: None
I am converting from a tail shifter to a side shifter. I have one but its history is unknown to me - it came out of a parts car that I've had for 10 years or so and it had been sitting in a dead car for unknown years before that. I've never rebuilt one so I approached a local expert about rebuilding it prior to putting it in the car but he recommenced that I stick it in and run it to get an idea of its condition before I spend any time or money on it. Not a bad plan just not what I had in mind.
I have cleaned it up and built a bracket to hold the accelerator linkage pivot shaft but after filling it with fresh oil, I've noticed that its leaking from the driver's side output shaft. Can the seal on this side be replaced easily? |
| Mikey914 |
Jul 5 2017, 11:05 AM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
Fix whats leaking now, keep an eye on it and take it out over the winter to service the entire unit. Don't loose valuable drive time now unless you have to. (IMG:style_emoticons/default/biggrin.gif)
| wndsrfr |
Jul 5 2017, 07:49 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,460 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region
Fix whats leaking now, keep an eye on it and take it out over the winter to service the entire unit. Don't loose valuable drive time now unless you have to. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/agree.gif) It's easy to do that output flange seal with the engine & trans in the car..... |
db9146 Side Shifter Trans Question Jul 4 2017, 08:52 PM
SirAndy Yes, output shaft seals are pretty straight forwar... Jul 4 2017, 09:02 PM
wndsrfr
Yes, output shaft seals are pretty straight forwa... Jul 5 2017, 04:27 AM
bdstone914 Do you have all of the other parts needed to make ... Jul 4 2017, 09:42 PM
Spoke I have one but its history is unknown to me
With ... Jul 4 2017, 10:24 PM
dlee6204 IMO you need to replace ALL the seals on the box o... Jul 5 2017, 05:43 AM
jkb944t
IMO you need to replace ALL the seals on the box ... Jul 5 2017, 05:50 AM
Dr Evil One thing to consider, and is common, especially i... Jul 13 2017, 10:35 AM![]() ![]() |
Lo-Fi Version | Time is now: 12th March 2026 - 09:41 PM |
