Won't start! Will start if I coast down hill and pop clutch! |
Ian Stott |
Jul 1 2017, 05:18 AM
Senior Member Group: Members Posts: 907 Joined: 28-January 08 From: Moncton/Canada Member No.: 8,635 Region Association: Canada |
As described! What is up with this situation? Engine runs beautiful when warmed up, will restart no problem if It has been shut off for even a few hours. Kudos to the battery and starter as I have tried to start it normally when it has been sitting for a few days, won't catch, thank goodness I live on a hill, coast down the hill a bit, put her in 3rd gear pop the clutch and vrooom! Have done this 6 times now!
Ian Stott Moncton Canada |
Mark Henry |
Jul 4 2017, 01:13 PM
Doubt if it's the battery itself, one year old odyssey 925.
IIRC new blue coil, or did I use the stock coil from my L-jet system? I do know I used the dizzy from my old L-jet You'll need a helper but try taking a voltage reading on the coil + wire when you start to crank cold. At least that should show if your volts drop when cranking. Vac leaks are always a possibility on an L-jet, even though I used new hose, replaced both cap seals, etc.... |
Spoke |
Jul 5 2017, 08:31 PM
Jerry Group: Members Posts: 6,991 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
You'll need a helper but try taking a voltage reading on the coil + wire when you start to crank cold. At least that should show if your volts drop when cranking. Have this test been done yet? That you can sit and crank the engine and it doesn't start, then push/coast start it I think shows it's an electrical problem and not an issue of vacuum leak or other engine issue. As others have said, perhaps it's the ignition switch. |
Lo-Fi Version | Time is now: 7th June 2024 - 05:05 PM |
