| TheWeatherMan |
Jul 5 2017, 12:45 PM
Newbie ![]() Group: Members Posts: 18 Joined: 2-July 17 From: Vienna, VA Member No.: 21,222 Region Association: MidAtlantic Region |
What modern EFI systems is everyone installing on their Type-IV engine?
| falcor75 |
Jul 6 2017, 01:47 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia
Must have:
Crank position sensor Throttle position sensor Coolant temp (warmup only) sensor Intake Air Temperature Sensor Wideband lambda sensor With this you can run Alpha-N in wasted spark, will run fine. Optional: MAP-sensor CHT-sensor(s) Cam position sensor Now you can run fully sequential and speed density and keep track of your CHT's. |
TheWeatherMan What modern EFI is everybody using Jul 5 2017, 12:45 PM
jd74914 I'm putting a MS3X (Megasquirt) on my 2.0L. No... Jul 5 2017, 01:31 PM
jimkelly seems very few have moved away from stock FI, and ... Jul 5 2017, 02:52 PM
porschetub There was a guy a few years back that used GM ECU ... Jul 5 2017, 03:38 PM
914forme
There was a guy a few years back that used GM ECU... Jul 5 2017, 09:06 PM
Mark Henry I installed SDS way back in 2004, still running th... Jul 5 2017, 03:54 PM
JamesM PEFI alone adds no HP, but a proper tune on top of... Jul 5 2017, 07:12 PM
914_teener
PEFI alone adds no HP, but a proper tune on top o... Jul 5 2017, 07:42 PM
JamesM
So James.....just as an observer. What is the mi... Jul 6 2017, 01:30 AM
Mark Henry
PEFI alone adds no HP, but a proper tune on top o... Jul 5 2017, 08:19 PM
JamesM
Marketing Koolaid :D
3D tuning table? does t... Jul 6 2017, 01:54 AM
Mueller I would guess that there are 5 to 10+ 914s that ar... Jul 5 2017, 04:14 PM
wndsrfr I'm on SDS on the 2316 Raby kit engine that Dr... Jul 5 2017, 07:47 PM
Dtjaden Megasquirt MS3X full engine management (FI and ign... Jul 5 2017, 08:39 PM
falcor75 Who's going to tune your car? If you know that... Jul 5 2017, 10:30 PM
Mueller
[b]Who's going to tune your car? If you know ... Jul 6 2017, 12:31 AM
JamesM
Must have:
Throttle positio... Jul 6 2017, 02:11 AM
falcor75
Must have:
Throttle positi... Jul 6 2017, 03:21 AM
jimkelly microsquirt diagram Jul 6 2017, 04:26 AM
ottox914 SDS. See my sig below for the install thread. It... Jul 6 2017, 06:08 AM
Mark Henry :agree:
I sold Dave his SDS system.
SDS is hand... Jul 6 2017, 07:35 AM
Mark Henry A member asked me if he should ditch his homebuilt... Jul 6 2017, 11:52 AM
90quattrocoupe Now before I start this post, I am not in anyway a... Jul 6 2017, 12:40 PM
Mark Henry That's one of the issues with many PEFI system... Jul 7 2017, 09:51 AM
TheWeatherMan Thanks, ill continue to research the SDS set up an... Jul 7 2017, 10:37 AM
Mark Henry
Thanks, ill continue to research the SDS set up a... Jul 7 2017, 11:38 AM![]() ![]() |
Lo-Fi Version | Time is now: 17th September 2026 - 06:12 AM |
