> Crazy ride home. Lots of dash stuff quit working.
malcolm2
post Jul 6 2017, 07:01 PM
Took a trip downtown to get some Brad Penn. Then to a favorite brewery, Honky Tonk Brewery. On the way home I hear the stereo stop, then start again. I then see almost nothing on the dash works. No RPM, speedo is working but too high. no oil temp or fuel, no a/f, no oil pressure, no blinkers, you name it. The G light is on cht gauge too tho. Hazzards and dash illumination work. Head lights work, fog lights work. All the rear lights work at once. No brakes, just tail, etc…
Guess i have a weekend project. Thoughts?
GregAmy
post Jul 7 2017, 06:34 AM
Subscribing. I'm popping F9 now on occasion. I truly wish it was a bad ground, 'cause if one of all those wires is fooked it'll be a bear to find...
OP, how's that fuse?
malcolm2   Crazy ride home. Lots of dash stuff quit working.   Jul 6 2017, 07:01 PM
tygaboy   Stock speedo? That'd be cable driven so...   Jul 6 2017, 07:06 PM
malcolm2   Stock speedo? That'd be cable driven so... ...   Jul 6 2017, 07:20 PM
euro911   Clark, the 'G' light is the generator (alt...   Jul 6 2017, 07:18 PM
euro911   I'd check for an intermittent ground. Check a...   Jul 6 2017, 08:33 PM
Spoke   Fuse S9 powers most of those things you mentioned ...   Jul 6 2017, 09:41 PM
malcolm2   Fuse S9 powers most of those things you mentioned...   Jul 7 2017, 07:06 AM
Dave_Darling   Yup, check the fuses. --DD   Jul 6 2017, 10:08 PM
euro911   Just curious ... if it was the fuse, wouldn't ...   Jul 6 2017, 10:28 PM
Spoke   Just curious ... if it was the fuse, wouldn't...   Jul 6 2017, 11:17 PM
malcolm2   The simplified schematic above omits the tach, ...   Jul 7 2017, 07:21 AM
Mark Henry   [b]Grounds....grounds everywhere... [img]http://ww...   Jul 7 2017, 06:31 AM
GregAmy   Subscribing. I'm popping F9 now on occasion. I...   Jul 7 2017, 06:34 AM
malcolm2   OK, nevermind... I guess I never knew the fuses we...   Jul 7 2017, 07:12 AM
GregAmy   What is the F or S for? The German word for ...   Jul 7 2017, 07:53 AM
Dave_Darling   Note that the stock fuse block has its connections...   Jul 7 2017, 01:02 PM
malcolm2   I don't want to think about what might have...   Jul 7 2017, 01:28 PM
Spoke   I was re-installing the fuse board once and the ...   Jul 7 2017, 04:59 PM
Kansas 914   Any time I drop the fuse panel I disconnect the ...   Jul 11 2017, 07:36 AM
malcolm2   TA-DA It was the fuse. The panel is bolted up tig...   Jul 7 2017, 03:28 PM
euro911   TA-DA It was the fuse. The panel is bolted up tig...   Jul 7 2017, 09:45 PM
Elliot Cannon   When trouble shooting electrical problems, I alway...   Jul 11 2017, 08:22 AM
malcolm2   as it turns out I believe this problem to be self ...   Jul 11 2017, 01:39 PM
- Lo-Fi Version Time is now: 30th April 2026 - 10:21 AM
