| malcolm2 |
Jul 6 2017, 07:01 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,749 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States
Took a trip downtown to get some Brad Penn. Then to a favorite brewery, Honky Tonk Brewery. On the way home I hear the stereo stop, then start again. I then see almost nothing on the dash works. No RPM, speedo is working but too high. no oil temp or fuel, no a/f, no oil pressure, no blinkers, you name it. The G light is on cht gauge too tho. Hazzards and dash illumination work. Head lights work, fog lights work. All the rear lights work at once. No brakes, just tail, etc…
Guess i have a weekend project. Thoughts? |
| Dave_Darling |
Jul 7 2017, 01:02 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,338 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
Note that the stock fuse block has its connections on the back, and they are quite close to the metal panel that holds the block. This panel is held onto the chassis with metal screws, meaning it is grounded (if often not all that well).
If your fuse block shifts a little in place, it can cause one of the connectors to momentarily touch the mounting panel, popping a fuse. Guess which one popped on my car every few weeks if I went over bumps? Hint: The tach dropped to zero and the charging light came on... In my case, one of the screws that holds the fuse block onto the mounting panel had gone MIA, and the block would shift sometimes when things got bouncy. I replaced the screw and I think I may have also put some split tubing along the edge of the panel to keep anything from bumping in the future. I don't want to think about what might have happened if it had been the other side of the fused connection that had shorted to ground.... --DD |
malcolm2 Crazy ride home. Lots of dash stuff quit working. Jul 6 2017, 07:01 PM
tygaboy Stock speedo? That'd be cable driven so... Jul 6 2017, 07:06 PM
malcolm2
... Jul 6 2017, 07:20 PM
euro911 Clark, the 'G' light is the generator (alt... Jul 6 2017, 07:18 PM
euro911 I'd check for an intermittent ground. Check a... Jul 6 2017, 08:33 PM
Spoke Fuse S9 powers most of those things you mentioned ... Jul 6 2017, 09:41 PM
malcolm2
Fuse S9 powers most of those things you mentioned... Jul 7 2017, 07:06 AM
Dave_Darling Yup, check the fuses.
--DD Jul 6 2017, 10:08 PM
euro911 Just curious ... if it was the fuse, wouldn't ... Jul 6 2017, 10:28 PM
Spoke
Just curious ... if it was the fuse, wouldn't... Jul 6 2017, 11:17 PM
malcolm2
The simplified schematic above omits the tach, ... Jul 7 2017, 07:21 AM
Mark Henry [b]Grounds....grounds everywhere...
[img]http://ww... Jul 7 2017, 06:31 AM
GregAmy Subscribing. I'm popping F9 now on occasion. I... Jul 7 2017, 06:34 AM
malcolm2 OK, nevermind... I guess I never knew the fuses we... Jul 7 2017, 07:12 AM
GregAmy What is the F or S for?
The German word for ... Jul 7 2017, 07:53 AM
malcolm2
I don't want to think about what might have... Jul 7 2017, 01:28 PM
Spoke
I was re-installing the fuse board once and the ... Jul 7 2017, 04:59 PM
Kansas 914
Any time I drop the fuse panel I disconnect the ... Jul 11 2017, 07:36 AM
malcolm2 TA-DA
It was the fuse. The panel is bolted up tig... Jul 7 2017, 03:28 PM
euro911 TA-DA
It was the fuse. The panel is bolted up tig... Jul 7 2017, 09:45 PM
Elliot Cannon When trouble shooting electrical problems, I alway... Jul 11 2017, 08:22 AM
malcolm2 as it turns out I believe this problem to be self ... Jul 11 2017, 01:39 PM![]() ![]() |
Lo-Fi Version | Time is now: 30th April 2026 - 10:22 AM |
