> Crazy ride home. Lots of dash stuff quit working.
malcolm2
post Jul 6 2017, 07:01 PM
Took a trip downtown to get some Brad Penn. Then to a favorite brewery, Honky Tonk Brewery. On the way home I hear the stereo stop, then start again. I then see almost nothing on the dash works. No RPM, speedo is working but too high. no oil temp or fuel, no a/f, no oil pressure, no blinkers, you name it. The G light is on cht gauge too tho. Hazzards and dash illumination work. Head lights work, fog lights work. All the rear lights work at once. No brakes, just tail, etc…
Guess i have a weekend project. Thoughts?
Dave_Darling
post Jul 7 2017, 01:02 PM
914 Idiot
Note that the stock fuse block has its connections on the back, and they are quite close to the metal panel that holds the block. This panel is held onto the chassis with metal screws, meaning it is grounded (if often not all that well).
If your fuse block shifts a little in place, it can cause one of the connectors to momentarily touch the mounting panel, popping a fuse.
Guess which one popped on my car every few weeks if I went over bumps? Hint: The tach dropped to zero and the charging light came on...
In my case, one of the screws that holds the fuse block onto the mounting panel had gone MIA, and the block would shift sometimes when things got bouncy. I replaced the screw and I think I may have also put some split tubing along the edge of the panel to keep anything from bumping in the future.
I don't want to think about what might have happened if it had been the other side of the fused connection that had shorted to ground....
--DD
malcolm2
post Jul 7 2017, 01:28 PM
QUOTE(Dave_Darling @ Jul 7 2017, 02:02 PM) *
--DD
I am leaving work now, looking forward to pulling that fuse #9! (IMG:style_emoticons/default/popcorn[1].gif)
I have the JWest type that I inserted above. I will take it down and take a close look.
I was re-installing the fuse board once and the "L" shaped bracket that accepts the hold down screws had slipped under one of the relays. sparks galore...
I am much more careful now-a-days, but it is hard to be watching all the edges and brackets and corners as you wedge that wired board back in place. I probably should disconnect the battery to be safe.... (IMG:style_emoticons/default/shades.gif)
malcolm2   Crazy ride home. Lots of dash stuff quit working.   Jul 6 2017, 07:01 PM
tygaboy   Stock speedo? That'd be cable driven so...   Jul 6 2017, 07:06 PM
malcolm2   Stock speedo? That'd be cable driven so... ...   Jul 6 2017, 07:20 PM
euro911   Clark, the 'G' light is the generator (alt...   Jul 6 2017, 07:18 PM
euro911   I'd check for an intermittent ground. Check a...   Jul 6 2017, 08:33 PM
Spoke   Fuse S9 powers most of those things you mentioned ...   Jul 6 2017, 09:41 PM
malcolm2   Fuse S9 powers most of those things you mentioned...   Jul 7 2017, 07:06 AM
Dave_Darling   Yup, check the fuses. --DD   Jul 6 2017, 10:08 PM
euro911   Just curious ... if it was the fuse, wouldn't ...   Jul 6 2017, 10:28 PM
Spoke   Just curious ... if it was the fuse, wouldn't...   Jul 6 2017, 11:17 PM
malcolm2   The simplified schematic above omits the tach, ...   Jul 7 2017, 07:21 AM
Mark Henry   [b]Grounds....grounds everywhere... [img]http://ww...   Jul 7 2017, 06:31 AM
GregAmy   Subscribing. I'm popping F9 now on occasion. I...   Jul 7 2017, 06:34 AM
malcolm2   OK, nevermind... I guess I never knew the fuses we...   Jul 7 2017, 07:12 AM
GregAmy   What is the F or S for? The German word for ...   Jul 7 2017, 07:53 AM
Dave_Darling   Note that the stock fuse block has its connections...   Jul 7 2017, 01:02 PM
malcolm2   I don't want to think about what might have...   Jul 7 2017, 01:28 PM
Spoke   I was re-installing the fuse board once and the ...   Jul 7 2017, 04:59 PM
Kansas 914   Any time I drop the fuse panel I disconnect the ...   Jul 11 2017, 07:36 AM
malcolm2   TA-DA It was the fuse. The panel is bolted up tig...   Jul 7 2017, 03:28 PM
euro911   TA-DA It was the fuse. The panel is bolted up tig...   Jul 7 2017, 09:45 PM
Elliot Cannon   When trouble shooting electrical problems, I alway...   Jul 11 2017, 08:22 AM
malcolm2   as it turns out I believe this problem to be self ...   Jul 11 2017, 01:39 PM
- Lo-Fi Version Time is now: 30th April 2026 - 10:21 AM
