| rpc |
Jul 7 2017, 03:14 PM
Member ![]() ![]() Group: Members Posts: 50 Joined: 18-May 11 From: Reston, VA Member No.: 13,084 Region Association: MidAtlantic Region |
History: We bought this '73 2.0 last summer. It ran ok at the time, though on cold start-up it would choke if we gave it throttle before it had a chance to warm up for a few minutes. We dropped the drivetrain in the fall to do a bunch of general cleanup on the engine and trans, including:
Today: We finally got everything back together and started the car but it was running really rich, so much so that we could barely keep it running. After we shut it off it wouldn't start again. It would spin fine, but not even a hint of firing. Things we've done:
So first, I think it's so badly flooded that we need to wait a day and/or pull the plugs so that the cylinders dry out. Second, I'm guessing that replacing the hoses fixed a bunch of air leaks, which some PO had compensated for by richening the mixture. I could very well be wrong, just a guess. I've read a good amount and have a basic understanding of the D-jet system, but I'm looking for pointers about where I should start in fixing this. If I'm right about the flooding we should be able to get it started. Then what do we need to start checking to address the rich running? |
| Dave_Darling |
Jul 7 2017, 06:41 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,335 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
How's the fuel pressure? A kinked return line, or hooking up the fuel pressure regulator backwards, will result in very high fuel pressure. Which means a rich mixture.
--DD |
rpc 73 2.0 running *really* rich Jul 7 2017, 03:14 PM
BeatNavy Rich - from your previous thread, did you find and... Jul 7 2017, 03:19 PM
brant test the vacuum of the MPS
then the range of the ... Jul 7 2017, 03:20 PM
Rand MPS was my first thought. See if it holds a vacuum... Jul 7 2017, 03:22 PM
rpc Guys,
Thanks, great info.
I'd read the car wo... Jul 7 2017, 05:47 PM
BeatNavy That CHT number doesn't seem out of whack in g... Jul 7 2017, 06:39 PM
rpc Good point about brittle wires. It seems the FI ha... Jul 8 2017, 07:29 AM
BeatNavy
Good point about brittle wires. It seems the FI h... Jul 8 2017, 04:40 PM
rpc
Before you do that, though, it's probably eas... Jul 9 2017, 06:58 AM
rpc My buddy checked the MPS vacuum today and found: ... Jul 9 2017, 04:27 PM
Rand You can get lucky with a used MPS on the cheap fro... Jul 9 2017, 04:35 PM
BeatNavy Hey Rich - that MPS is not serviceable. It may no... Jul 9 2017, 04:38 PM
rpc Thanks again, guys. Looks like the Tangerine Racin... Jul 9 2017, 04:56 PM
rpc Today's update:
Turns out the MPS leak isn... Jul 11 2017, 04:10 PM
BeatNavy :Qarl: :beer1: :Qarl:
So the CSV was the gui... Jul 11 2017, 04:28 PM
rpc I sent an email to the WitchHunter folks and asked... Jul 25 2017, 01:13 PM
boxsterfan You probably don't need the CSV if you don... Jul 25 2017, 01:39 PM
rpc
You probably don't need the CSV if you don... Jul 25 2017, 01:50 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 06:41 PM |
