| malcolm2 |
Jul 6 2017, 07:01 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,749 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States
Took a trip downtown to get some Brad Penn. Then to a favorite brewery, Honky Tonk Brewery. On the way home I hear the stereo stop, then start again. I then see almost nothing on the dash works. No RPM, speedo is working but too high. no oil temp or fuel, no a/f, no oil pressure, no blinkers, you name it. The G light is on cht gauge too tho. Hazzards and dash illumination work. Head lights work, fog lights work. All the rear lights work at once. No brakes, just tail, etc…
Guess i have a weekend project. Thoughts? |
| malcolm2 |
Jul 7 2017, 03:28 PM
| euro911 |
Jul 7 2017, 09:45 PM
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,937 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California
TA-DA (IMG:style_emoticons/default/cheer.gif) It was the fuse. The panel is bolted up tight. I'll pull it down tomorrow and give it a once over. Thanks to all. |
malcolm2 Crazy ride home. Lots of dash stuff quit working. Jul 6 2017, 07:01 PM
tygaboy Stock speedo? That'd be cable driven so... Jul 6 2017, 07:06 PM
malcolm2
... Jul 6 2017, 07:20 PM
euro911 Clark, the 'G' light is the generator (alt... Jul 6 2017, 07:18 PM
euro911 I'd check for an intermittent ground. Check a... Jul 6 2017, 08:33 PM
Spoke Fuse S9 powers most of those things you mentioned ... Jul 6 2017, 09:41 PM
malcolm2
Fuse S9 powers most of those things you mentioned... Jul 7 2017, 07:06 AM
Dave_Darling Yup, check the fuses.
--DD Jul 6 2017, 10:08 PM
euro911 Just curious ... if it was the fuse, wouldn't ... Jul 6 2017, 10:28 PM
Spoke
Just curious ... if it was the fuse, wouldn't... Jul 6 2017, 11:17 PM
malcolm2
The simplified schematic above omits the tach, ... Jul 7 2017, 07:21 AM
Mark Henry [b]Grounds....grounds everywhere...
[img]http://ww... Jul 7 2017, 06:31 AM
GregAmy Subscribing. I'm popping F9 now on occasion. I... Jul 7 2017, 06:34 AM
malcolm2 OK, nevermind... I guess I never knew the fuses we... Jul 7 2017, 07:12 AM
GregAmy What is the F or S for?
The German word for ... Jul 7 2017, 07:53 AM
Dave_Darling Note that the stock fuse block has its connections... Jul 7 2017, 01:02 PM
malcolm2
I don't want to think about what might have... Jul 7 2017, 01:28 PM
Spoke
I was re-installing the fuse board once and the ... Jul 7 2017, 04:59 PM
Kansas 914
Any time I drop the fuse panel I disconnect the ... Jul 11 2017, 07:36 AM
Elliot Cannon When trouble shooting electrical problems, I alway... Jul 11 2017, 08:22 AM
malcolm2 as it turns out I believe this problem to be self ... Jul 11 2017, 01:39 PM![]() ![]() |
Lo-Fi Version | Time is now: 30th April 2026 - 10:20 AM |
