| malcolm2 |
Jul 6 2017, 07:01 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,749 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States
Took a trip downtown to get some Brad Penn. Then to a favorite brewery, Honky Tonk Brewery. On the way home I hear the stereo stop, then start again. I then see almost nothing on the dash works. No RPM, speedo is working but too high. no oil temp or fuel, no a/f, no oil pressure, no blinkers, you name it. The G light is on cht gauge too tho. Hazzards and dash illumination work. Head lights work, fog lights work. All the rear lights work at once. No brakes, just tail, etc…
Guess i have a weekend project. Thoughts? |
| Elliot Cannon |
Jul 11 2017, 08:22 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None
When trouble shooting electrical problems, I always first check the easiest things to test. The fuse is usually the easiest to reach and look at. Check the switch is in the correct position, check that the bulb isn't burnt out. If all of them check out OK, take a deep breath and drag out the multi-meter and the wiring diagram and ask for help. (IMG:style_emoticons/default/av-943.gif)
malcolm2 Crazy ride home. Lots of dash stuff quit working. Jul 6 2017, 07:01 PM
tygaboy Stock speedo? That'd be cable driven so... Jul 6 2017, 07:06 PM
malcolm2
... Jul 6 2017, 07:20 PM
euro911 Clark, the 'G' light is the generator (alt... Jul 6 2017, 07:18 PM
euro911 I'd check for an intermittent ground. Check a... Jul 6 2017, 08:33 PM
Spoke Fuse S9 powers most of those things you mentioned ... Jul 6 2017, 09:41 PM
malcolm2
Fuse S9 powers most of those things you mentioned... Jul 7 2017, 07:06 AM
Dave_Darling Yup, check the fuses.
--DD Jul 6 2017, 10:08 PM
euro911 Just curious ... if it was the fuse, wouldn't ... Jul 6 2017, 10:28 PM
Spoke
Just curious ... if it was the fuse, wouldn't... Jul 6 2017, 11:17 PM
malcolm2
The simplified schematic above omits the tach, ... Jul 7 2017, 07:21 AM
Mark Henry [b]Grounds....grounds everywhere...
[img]http://ww... Jul 7 2017, 06:31 AM
GregAmy Subscribing. I'm popping F9 now on occasion. I... Jul 7 2017, 06:34 AM
malcolm2 OK, nevermind... I guess I never knew the fuses we... Jul 7 2017, 07:12 AM
GregAmy What is the F or S for?
The German word for ... Jul 7 2017, 07:53 AM
Dave_Darling Note that the stock fuse block has its connections... Jul 7 2017, 01:02 PM
malcolm2
I don't want to think about what might have... Jul 7 2017, 01:28 PM
Spoke
I was re-installing the fuse board once and the ... Jul 7 2017, 04:59 PM
Kansas 914
Any time I drop the fuse panel I disconnect the ... Jul 11 2017, 07:36 AM
malcolm2 TA-DA
It was the fuse. The panel is bolted up tig... Jul 7 2017, 03:28 PM
euro911 TA-DA
It was the fuse. The panel is bolted up tig... Jul 7 2017, 09:45 PM
malcolm2 as it turns out I believe this problem to be self ... Jul 11 2017, 01:39 PM![]() ![]() |
Lo-Fi Version | Time is now: 30th April 2026 - 10:22 AM |
