mzalanka |
Member ![]() ![]() Group: Members Posts: 116 Joined: 11-July 11 From: Portland, OR Member No.: 13,300 Region Association: None ![]() |
I'm reposting my question from yesterday, which was poorly received. In hindsight I should have just asked the question and skipped the degree of detail and lame attempts at humor. Wish delete was an option.
Two clutch-related problems: clutch pedal feel that gets "notchy" or, for lack of a better term, "not smooth" as the engine warms, and also judder or grabbing from take-off in first (also gets worse as engine warms). I do not know my way around a clutch or a transmission. The one installed was put in by the engine rebuilder and sat for 5 years. Vehicle has new pressure plate, friction disk, TOB, Gemo cable, rebuilt pedal cluster. Just fixed an input shaft leak, drove about 100 miles on it. Seems like that could explain the grabbing but not the worsening notchiness, which is still present even when engine is off, warm, and has been present since Mile 0. I've ordered a clutch kit from PP and will probably just replace the whole thing, but what specifically should I be looking for in terms of faults? Thanks. Long time lurker but rare poster. Greatly appreciate the World. |
Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
Was your flywheel resurfaced? That will set your distance from your trans further so the ball has to be shimmed with 2 washers and put some Teflon tape on the threads (very little) as it will leak otherwise.
euro911 |
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,851 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California ![]() ![]() |
Was your flywheel resurfaced? That will set your distance from your trans further so the ball has to be shimmed with 2 washers and put some Teflon tape on the threads (very little) as it will leak otherwise. Mike, with the threads being so short on the OEMs, what do you think about having some new ones made with longer threads to allow for more shims? |
Dr Evil |
Was your flywheel resurfaced? That will set your distance from your trans further so the ball has to be shimmed with 2 washers and put some Teflon tape on the threads (very little) as it will leak otherwise. Mike, with the threads being so short on the OEMs, what do you think about having some new ones made with longer threads to allow for more shims?Dude, if you need more than two washers, that flywheel is toast. The threads havent been any issues in the past with these being backed out two washers worth. |
Lo-Fi Version | Time is now: 15th June 2024 - 04:59 AM |
