Removing Old Door Fuzzy, HELP |
1adam12 |
Jul 13 2017, 03:26 PM
Member Group: Members Posts: 209 Joined: 25-May 17 From: Chino Hills, CA Member No.: 21,132 Region Association: Southern California |
Hi everyone! I'm trying to install a new set of outer door fuzzies I recently purchased from 914rubber but I'm having a hell of a time removing the old fuzzy. I was able to locate and remove the 3 screws that hold the original fuzzy in place but it's been difficult trying to get the old decrepit fuzzy strip out of the retaining bracket?
Does this bracket come off somehow because it's a pain trying to pick and break up the old strip through the top of the door. Even if I was able to break up most of the old strip, the top metal portion would still be lodged within the top of the bracket. Attached thumbnail(s) |
Mikey914 |
Jul 13 2017, 06:07 PM
The rubber man Group: Members Posts: 12,671 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
We do make replacement aluminum strips if you need them, but you shohld be able to push down. Hopefully not a broken screw, but if you look st the ones you removed you can tell. Take a wood shim and tap down on it as not to damage the old track but if you need them we do have new ones.
Mark http://shop.914rubber.com/91453195910-Door...m?categoryId=-1 |
Lo-Fi Version | Time is now: 23rd May 2024 - 10:20 AM |
