Power Steering?, ouch...this is gonna hurt! |
Sean_S |
Oct 31 2004, 12:29 PM
Mine goes to "11" Group: Members Posts: 48 Joined: 21-October 04 From: Coos Bay, OR Member No.: 2,979 |
Ok, I know I'll be walkin' the plank for this but I figured it's a good day for it.
Assuming I could find a place to mount a pump, can power steering be retrofitted into the 914? Has this been done before? I'll answer the obvious question I'm going to get...why? Well, I'm not really sure what I'm building (finishing) here. My car is likely not going to race well (even if I could find a "class" to race in), and it's not really a classic anymore. I guess what I'm going to go for is as close to a "mid-life-crisis" luxury sports car from a 914 as can be accomplished...a novelty I suppose but perhaps unique in it's own way. Another "flavor" if you will. I'll use the V8 power to offset the weight of the DVD player, amps, extra sound insulation...blah blah blah. I guess you see where I'm going here. I will try to do it with some sense of style and tradition though and not "pimp" it. In any case, the car has 10's in front and 12's in the rear...it's a lot of rubber to move. So, to protect my limp wrists (Sure that was coming LOL!), any ideas, links, sources, and thoughts on a PS rack in the 914? Many thanks Sean S (IMG:style_emoticons/default/driving.gif) |
Mueller |
Oct 31 2004, 09:59 PM
here you go...with this method you can keep the stock rack and pinion:
power assist steering basicly an electric motor is attached to the steering column shaft (I'm guessing there might be enough room behind the gas tank), then when you start to turn, the motor engergizes to help the steering shaft turn. |
Lo-Fi Version | Time is now: 23rd May 2024 - 09:00 AM |
