Running really rich, 1973 1.7 FI |
tbone1819 |
Jul 18 2017, 03:06 PM
Newbie Group: Members Posts: 26 Joined: 1-February 17 From: Lynbrook NY Member No.: 20,800 Region Association: North East States |
Ok,
So my 73 was running great until it slowly started to go down hill. Car would not start after it was running/driving for a while but the next day would fire right up. Recenltly changed the oil that was completly diluted with gasoline. WTF?? |
Dave_Darling |
Jul 18 2017, 04:45 PM
Gas has washed past the rings and into the sump. Good thing you changed it; gasoline does not lubricate like oil does. This happens any time the mixture is rich enough that the engine almost doesn't run.
Things to check: Fuel pressure, disconnected wires (especially head temp sensor wire), MPS that won't hold vacuum, unplugged hoses... --DD |
tbone1819 |
Jul 18 2017, 07:36 PM
Gas has washed past the rings and into the sump. Good thing you changed it; gasoline does not lubricate like oil does. This happens any time the mixture is rich enough that the engine almost doesn't run. Things to check: Fuel pressure, disconnected wires (especially head temp sensor wire), MPS that won't hold vacuum, unplugged hoses... --DD Thanks I will check that out. |
Lo-Fi Version | Time is now: 12th June 2024 - 01:17 AM |
