Rear wheels dragging |
andrewmlin |
Jul 20 2017, 05:30 PM
'74 2.0 Group: Members Posts: 22 Joined: 20-June 11 From: San Bruno, CA Member No.: 13,220 Region Association: Northern California |
1974 Porsche 914 2.0. My parking brake doesn't fully engage. When I'm on a hill, the car slides (with some drag). Today, I put the car up on stands and removed the rear wheels. First thing I noticed was that the rear left wheel has A LOT of drag without parking brake engaged. The rear right is better. I set the venting clearances on both the outside adjusters to .004, but the inside adjuster caps are stripped, so I'm going to have to pull off the calipers and figure that out.
Question though, how do I know if the calipers are seized? Or could it be the lines? Or simply the inner adjuster clearances? |
tomh |
Jul 20 2017, 07:08 PM
Member Group: Members Posts: 322 Joined: 28-February 10 From: san jose Member No.: 11,412 Region Association: None |
You need to set the proper venting clearance.
I found a little controversy on this subject so hopefully everyone will chime in on this and you will get the correct info. |
Lo-Fi Version | Time is now: 9th June 2024 - 07:16 PM |
