> Brake bleeding help
steuspeed
post Jul 22 2017, 05:23 PM
Installed a new Ate 17mm Master and rebuilt the right rear caliper. It was sticking on. I have gone around several times bleeding each corner with the pedal method. It still does not feel 100% solid. Any suggestions out there? Maybe air trapped by the top bleeders? I'm using Ate super blue which I found is no longer available (IMG:style_emoticons/default/hissyfit.gif) I did not bench bleed the master.
jsaum
post Jul 23 2017, 08:02 PM
Are you getting any pedal or is it going all the way to the floor? Did you start bleeding the caliper farthest away from the master cylinder and work your way around to the closest? I had to use a vacuum pump and speed bleeders to do mine when I rebuilt all of the calipers. Stick with it you'll get it.
steuspeed
post Jul 23 2017, 08:48 PM
QUOTE(jsaum @ Jul 23 2017, 07:02 PM) *
Yes, I do have some pedal. It feels like 80%. If feels like the pedal goes further down then I remember. The car was under cover most of the winter, so my memory may not be accurate. I started at the RR, LR, RF, LF. I have done tops and bottoms. Then all kinds of random order chasing an air pocket. Now I'm getting low on my super blue fluid can. I would like to solve this before I run out. It's driveable, but not for confident for panic stopping.
steuspeed   Brake bleeding help   Jul 22 2017, 05:23 PM
76-914   You might be pissing up a rope until you get that ...   Jul 23 2017, 07:58 AM
steuspeed   You might be pissing up a rope until you get that...   Jul 23 2017, 07:53 PM
banananose914   You might be pissing up a rope until you get that...   Jul 23 2017, 09:15 PM
porschetub   You might be pissing up a rope until you get that...   Jul 23 2017, 09:54 PM
steuspeed   You might be pissing up a rope until you get tha...   Jul 24 2017, 02:14 AM
michael7810   You can bleed the MC by cracking the lines one at ...   Jul 23 2017, 08:06 AM
steuspeed   You can bleed the MC by cracking the lines one at...   Jul 23 2017, 07:52 PM
mlindner   And then there's the pressure regulator, air m...   Jul 23 2017, 08:47 AM
GeorgeRud   I had good luck by pressure bleeding the brakes, t...   Jul 23 2017, 07:59 PM
jsaum   Are you getting any pedal or is it going all the w...   Jul 23 2017, 08:02 PM
steuspeed   Are you getting any pedal or is it going all the ...   Jul 23 2017, 08:48 PM
Perry Kiehl   Here you go Stu Here's how I bleed a 914 brake...   Jul 23 2017, 08:27 PM
steuspeed   Here you go Stu Here's how I bleed a 914 brak...   Jul 23 2017, 08:54 PM
Dave_Darling   Maybe air trapped by the top bleeders? Are you n...   Jul 23 2017, 09:29 PM
steuspeed   Maybe air trapped by the top bleeders? Are you ...   Jul 23 2017, 09:35 PM
McMark   First, make sure the plunger on the brake pedal is...   Jul 24 2017, 05:13 AM
Racer   Yes, ATE blue is no longer available.. only Gold. ...   Jul 24 2017, 09:32 AM
mepstein   If you don't have an impact wrench for removin...   Jul 24 2017, 09:54 AM
steuspeed   So my buddy brought over his Modine pressure brake...   Aug 14 2017, 11:48 PM
McMark   You ended up doing it in an usual way, but you bas...   Aug 15 2017, 01:48 PM
- Lo-Fi Version Time is now: 11th June 2026 - 01:23 AM
