> Brake bleeding help
steuspeed
post Jul 22 2017, 05:23 PM
Installed a new Ate 17mm Master and rebuilt the right rear caliper. It was sticking on. I have gone around several times bleeding each corner with the pedal method. It still does not feel 100% solid. Any suggestions out there? Maybe air trapped by the top bleeders? I'm using Ate super blue which I found is no longer available (IMG:style_emoticons/default/hissyfit.gif) I did not bench bleed the master.
Dave_Darling
post Jul 23 2017, 09:29 PM
914 Idiot
QUOTE(steuspeed @ Jul 22 2017, 04:23 PM) *
Are you not using the top bleeders? If not, you will never get the air out of the calipers.
--DD
steuspeed   Brake bleeding help   Jul 22 2017, 05:23 PM
76-914   You might be pissing up a rope until you get that ...   Jul 23 2017, 07:58 AM
steuspeed   You might be pissing up a rope until you get that...   Jul 23 2017, 07:53 PM
banananose914   You might be pissing up a rope until you get that...   Jul 23 2017, 09:15 PM
porschetub   You might be pissing up a rope until you get that...   Jul 23 2017, 09:54 PM
steuspeed   You might be pissing up a rope until you get tha...   Jul 24 2017, 02:14 AM
michael7810   You can bleed the MC by cracking the lines one at ...   Jul 23 2017, 08:06 AM
steuspeed   You can bleed the MC by cracking the lines one at...   Jul 23 2017, 07:52 PM
mlindner   And then there's the pressure regulator, air m...   Jul 23 2017, 08:47 AM
GeorgeRud   I had good luck by pressure bleeding the brakes, t...   Jul 23 2017, 07:59 PM
jsaum   Are you getting any pedal or is it going all the w...   Jul 23 2017, 08:02 PM
steuspeed   Are you getting any pedal or is it going all the ...   Jul 23 2017, 08:48 PM
Perry Kiehl   Here you go Stu Here's how I bleed a 914 brake...   Jul 23 2017, 08:27 PM
steuspeed   Here you go Stu Here's how I bleed a 914 brak...   Jul 23 2017, 08:54 PM
Dave_Darling   Maybe air trapped by the top bleeders? Are you n...   Jul 23 2017, 09:29 PM
steuspeed   Maybe air trapped by the top bleeders? Are you ...   Jul 23 2017, 09:35 PM
McMark   First, make sure the plunger on the brake pedal is...   Jul 24 2017, 05:13 AM
Racer   Yes, ATE blue is no longer available.. only Gold. ...   Jul 24 2017, 09:32 AM
mepstein   If you don't have an impact wrench for removin...   Jul 24 2017, 09:54 AM
steuspeed   So my buddy brought over his Modine pressure brake...   Aug 14 2017, 11:48 PM
McMark   You ended up doing it in an usual way, but you bas...   Aug 15 2017, 01:48 PM
- Lo-Fi Version Time is now: 11th June 2026 - 01:22 AM
