| steuspeed |
Jul 22 2017, 05:23 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,011 Joined: 12-July 11 From: Portland, Oregon Member No.: 13,308 Region Association: Pacific Northwest |
Installed a new Ate 17mm Master and rebuilt the right rear caliper. It was sticking on. I have gone around several times bleeding each corner with the pedal method. It still does not feel 100% solid. Any suggestions out there? Maybe air trapped by the top bleeders? I'm using Ate super blue which I found is no longer available (IMG:style_emoticons/default/hissyfit.gif) I did not bench bleed the master.
| Dave_Darling |
Jul 23 2017, 09:29 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,342 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
| steuspeed |
Jul 23 2017, 09:35 PM
steuspeed Brake bleeding help Jul 22 2017, 05:23 PM
76-914 You might be pissing up a rope until you get that ... Jul 23 2017, 07:58 AM
steuspeed
You might be pissing up a rope until you get that... Jul 23 2017, 07:53 PM
banananose914
You might be pissing up a rope until you get that... Jul 23 2017, 09:15 PM
porschetub
You might be pissing up a rope until you get that... Jul 23 2017, 09:54 PM
steuspeed
You might be pissing up a rope until you get tha... Jul 24 2017, 02:14 AM
michael7810 You can bleed the MC by cracking the lines one at ... Jul 23 2017, 08:06 AM
steuspeed
You can bleed the MC by cracking the lines one at... Jul 23 2017, 07:52 PM
mlindner And then there's the pressure regulator, air m... Jul 23 2017, 08:47 AM
GeorgeRud I had good luck by pressure bleeding the brakes, t... Jul 23 2017, 07:59 PM
jsaum Are you getting any pedal or is it going all the w... Jul 23 2017, 08:02 PM
steuspeed
Are you getting any pedal or is it going all the ... Jul 23 2017, 08:48 PM
Perry Kiehl Here you go Stu
Here's how I bleed a 914 brake... Jul 23 2017, 08:27 PM
steuspeed
Here you go Stu
Here's how I bleed a 914 brak... Jul 23 2017, 08:54 PM
McMark First, make sure the plunger on the brake pedal is... Jul 24 2017, 05:13 AM
Racer Yes, ATE blue is no longer available.. only Gold. ... Jul 24 2017, 09:32 AM
mepstein If you don't have an impact wrench for removin... Jul 24 2017, 09:54 AM
steuspeed So my buddy brought over his Modine pressure brake... Aug 14 2017, 11:48 PM
McMark You ended up doing it in an usual way, but you bas... Aug 15 2017, 01:48 PM![]() ![]() |
Lo-Fi Version | Time is now: 11th June 2026 - 01:22 AM |
