> Non-Stock Fuel Filters, for carbs, aftermarket FI, relocated pumps, engine swaps....
McMark
post Jul 24 2017, 08:56 AM
914 Freak!
I see this quite a bit and wanted to share my opinions on non-stock fuel filters. There are a ton of reasons the people would install different fuel filters, ranging from installing carbs, to relocating the fuel pump, to running aftermarket FI, engine swaps, upgrading to modern technology, etc.
The #1 thing to look at when choosing an aftermarket filter is the filter element size. These are measured in microns. Fuel Injection should have a 10 micron filter, carbs can get away with something larger, up to 40 microns (but that's getting pretty big).
The #2 thing to look at is the actual filter body size. Here's you're trying to make sure you have a filter unit that fits where you want it to, but also has enough size to deal with contamination over time. A tiny filter body has a tiny filter inside, and a tiny filter will start to lose flow sooner as contaminants collect in the filter element.
One rule-of-thumb that I start off with when trying to select a filter is starting my search with OE filters for newer cars. These are all built to for fuel injection (<10micron) and built to last for a reasonable life span (years). This is a bit of a complicated way to search, because you have to look at a lot of pictures. A lot of these filters don't explicitly call out the micron rating, but if it's made for modern FI and it's a reputable brand (FRAM is not reputable, for example) you can pretty safely assume it's a good filter.
Most people start their filter search on eBay, Amazon, or Summit (etc). A lot of these aftermarket filters are washable, billet aluminum, and lots of other fancy features. And a LOT of them are built to attract uninformed bargain hunters, who buy what's cheap, looks neat and says 'fuel filter' in the name.
Here's a filter I just pulled off a car. It's a Sniper Motorsports (a division of Holley) filter. It's rated at 30microns (way too coarse for FI) and it's tiny. I'm installing a Mahle KL 65 filter which is used on some Boxsters, have correct 5/16" nipples on either end, Mahle mentions 'up to 1 micron' filtration (doubtful, but I'm confident it's <10microns), and it's HUGE. This filter will do it's job well and will last for a long time.
One final note, clear plastic filters are 'neat' to look at, but are always not-great filters. The 'lowest' quality filter I would put on any 914 is the stock 914 filter. But this KL 65 is a better choice as long as it fits where you want to put it.
Hopefully this is helpful knowledge.
porschetub
post Jul 25 2017, 12:52 AM
Not keen on any fuel filter in the engine space for obvious reasons,the filter needs to be @ at the source of suction ,anyone keen to tell me otherwise go ahead,but suction @ the point of supply is where you have a filter...period.
Many pumps used are great @ suction but most pumps are crap @ drawing fuel from an indirect source ,funny how Porsche moved the pump to the front,folks think it was vapour lock not really the full story.
Its fine to add a second filter in the engine space as Mark has shown,just don't like plastic stuff around that heat and environment ..asking for serious issues IMO.
jim_hoyland
post Jul 25 2017, 05:47 AM
Get that VIN ?
QUOTE(porschetub @ Jul 24 2017, 11:52 PM) *
You say'n it could be a problem ? (IMG:style_emoticons/default/poke.gif)
McMark   Non-Stock Fuel Filters   Jul 24 2017, 08:56 AM
7TPorsh   Great info! Would the size of the filter (vo...   Jul 24 2017, 09:02 AM
McMark   The volume of the filter body won't affect fue...   Jul 24 2017, 09:09 AM
rgalla9146   Great information. Thank you. AFAI...   Jul 24 2017, 09:42 AM
Kansas 914   Great information. Thank you. AFA...   Jul 24 2017, 10:57 AM
Andyrew   I had a relatively small (2" wide by 8" ...   Jul 24 2017, 10:14 AM
Dave_Darling   I am confident I dont want to go back to a 10 mic...   Jul 24 2017, 11:39 AM
SirAndy   I can live with throwing away a filter a couple of...   Jul 24 2017, 11:49 AM
Andyrew   I am confident I dont want to go back to a 10 mi...   Jul 24 2017, 01:15 PM
McMark   I havent been able to find a 10 micron filter for ...   Jul 24 2017, 05:25 PM
Andyrew   I havent been able to find a 10 micron filter for...   Jul 24 2017, 10:00 PM
McMark   You would think... Right now Im making about as mu...   Jul 25 2017, 06:58 AM
jim_hoyland   Generally I'm putting pumps and filters under ...   Jul 25 2017, 07:29 AM
McMark   Generally I'm putting pumps and filters under...   Jul 25 2017, 07:56 AM
jim_hoyland   [quote name='jim_hoyland' post='2509912' date='Ju...   Jul 25 2017, 08:38 AM
forrestkhaag   Good information. I also added a cut-off valve in...   Jul 24 2017, 11:10 AM
jim_hoyland   Good information. I also added a cut-off valve i...   Jul 24 2017, 11:54 AM
SirAndy   I'm installing a Mahle KL 65 filter which is u...   Jul 24 2017, 11:21 AM
SirAndy   That looks strikingly similar to the fuel filter i...   Jul 24 2017, 11:27 AM
Larmo63   I am using a Pierburg type pump mounted up front w...   Jul 24 2017, 12:03 PM
Larmo63   RE: Non-Stock Fuel Filters   Jul 24 2017, 12:03 PM
porschetub   Not keen on any fuel filter in the engine space fo...   Jul 25 2017, 12:52 AM
jim_hoyland   Not keen on any fuel filter in the engine space f...   Jul 25 2017, 05:47 AM
DennisV   I thought I'd share the advice I got from Mike...   Jun 10 2026, 05:04 PM
6 User(s) are reading this topic (5 Guests and 0 Anonymous Users)
1 Members: Alden
- Lo-Fi Version Time is now: 10th June 2026 - 10:31 PM
