Throw out bearing?, only when cold |
ericoneal |
Jul 17 2017, 06:57 AM
Member Group: Members Posts: 320 Joined: 13-August 12 From: Crestwood, KY Member No.: 14,795 Region Association: South East States |
Whenever I start my car when its cold and press the clutch, its making an awful rattling sound, even at idle. The noise increases as a push on the clutch pedal and from my research on here and YouTube, it sounds like the throw-out bearing on the transmission.
The odd part of all of this is that it only happens when the engine is cold. Once I let her warm up for a few minutes, the noise is gone by the time I'm leaving the house (Reverse, then Forward, then no more sound) Everything seems to be shifting fine and the noise disappears. Something is going on down there, do you guys think its safe, mechanically, to drive it like this for awhile or will a worn throw-out cause more damage? Seems like an easy fix as soon as I can get time to drop the tranmission. |
ericoneal |
Aug 6 2017, 01:26 PM
Still have this noise happening, only when the engine is cold, or at least thats only when its noticeable.
I had my wife push the clutch with me under it, dont see anything obvious. Engine and transmission mounts seem to be fine at a glance. Whats odd is that it seems to me to be coming from near the fan, or at least near the front of the engine. It also seems to be correlated with RPM. Maybe a fan bearing? Still does not explain why the noise goes away when the engine is warm? Also adjusted the valves for good measure to no effect. Any ideas here would be great. Thanks, Eric |
Lo-Fi Version | Time is now: 14th June 2024 - 10:56 PM |
