| DennisO |
Aug 6 2017, 08:56 AM
Member ![]() ![]() Group: Members Posts: 61 Joined: 9-June 17 From: Clayton, NC Member No.: 21,162 Region Association: South East States
Hi All,
I plan to rebuild the 1.8L in my '75 project. The engine is original and complete with the L-jet fuel injection. I want to keep the original L-Jet Fuel Injection and was wondering what are good P&C sets for this engine if I don't want to change the fuel injection system? Reliability is my highest priority for the rebuild. The PET catalog has 022198075A listed as the part number for 1.8L, but it also has this part number listed for the 2.0, so I'm not sure if it's correct. Is Mahle the OEM vendor for these engines? Thanks in Advance, Dennis |
| bernbomb914 |
Aug 8 2017, 09:00 PM
one of the oldest Farts on this board ![]() ![]() ![]() Group: Benefactors Posts: 1,873 Joined: 29-December 02 From: Temecula, CA Member No.: 36 |
Iused Jahns Pistons told them what rods I was using
DennisO P&C Set Recommendations for a 1.8L Rebuild Aug 6 2017, 08:56 AM
McMark L-Jet is capable of running a larger engine. I wo... Aug 6 2017, 11:19 AM
DennisO Thanks - good to know about new Mahle.
Are the sto... Aug 6 2017, 11:36 AM
jim_hoyland
L-Jet is capable of running a larger engine. I w... Aug 6 2017, 04:37 PM
Dave_Darling Stock 1.8L cylinders are 93mm diameter.
The 96mm ... Aug 6 2017, 05:21 PM
DennisO Dave,
Do the 96mm pistons raise the compression r... Aug 6 2017, 06:41 PM
DennisO Hi Jim,
thanks for the info. Do you have the p/n... Aug 6 2017, 07:05 PM
jim_hoyland
Hi Jim,
thanks for the info. Do you have the p/... Aug 6 2017, 08:20 PM
DennisO thanks! Aug 6 2017, 08:24 PM
jim_hoyland This is the TB restoration link:
pbeslins@msn.com... Aug 6 2017, 09:25 PM
McMark Get these 96s.
You'll need to calculate t... Aug 7 2017, 06:13 AM
jsaum
Get these 96s.
You'll need to calculate ... Aug 7 2017, 06:49 PM
porschetub
[quote name='McMark' post='2514366' date='Aug 7 2... Aug 7 2017, 11:30 PM
JOEPROPER What is the recommended camshaft or cylinder head ... Aug 7 2017, 06:20 AM
McMark
What is the recommended camshaft or cylinder head... Aug 7 2017, 06:31 AM
saigon71
What is the recommended camshaft or cylinder hea... Aug 8 2017, 06:29 AM
DennisO Wow - this is exvellent info. Thank you.
I receiv... Aug 7 2017, 08:22 AM
echocanyons Lots of great information on this thread.
What wo... Aug 7 2017, 08:31 AM
McMark 66mm cranks (1.7/1.8) have a larger 'big end... Aug 7 2017, 11:17 AM
jim_hoyland One other thing that helped was the replacement of... Aug 7 2017, 02:49 PM
DennisO thanks Guys. What a wealth of great info.
The sl... Aug 7 2017, 09:49 PM
wndsrfr
The s... Aug 8 2017, 06:11 AM
jim_hoyland Rings need to get seated properly: there are proce... Aug 8 2017, 05:31 AM
porschetub Sorry forgot Hastings rings are used also ,appears... Aug 8 2017, 11:31 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:39 AM |
