> Weber IDF Jetting
FastFroggy
post Jun 30 2017, 12:20 PM
I am starting to play around with tuning and plan to start getting some small increments in jetting. Just to see if I can improve drivability for now. I have twin 44s
Simple question for now: I need 4 turns of idle mixture to now stumble off the line. Should I consider jetting richer?
thanks
ThePaintedMan
post Aug 9 2017, 06:30 AM
36 venturis in 44s for a 1.7 liter is HUGE. I'd hate to say start over with a track day so close, but if you're looking for better drivability, that large of a venturi is really hampering the intake "signal" running through the carb. For reference, I have a 1.8 and run 40 IDFs with 28 venturis. I would also imagine that with those venturis, you're not getting enough of an effect on the idle circuit to pull the fuel through them, which is why you need to open them so much. But that's just a SWAG (scientific wild ass guess).
For a track day, you're going to be full throttle most of the time anyway, and at high rpms, so you might want to stick with what you've got till you have more time to play with it.
FastFroggy   Weber IDF Jetting   Jun 30 2017, 12:20 PM
Perry Kiehl   Idle speed screws or mixture screws? There's ...   Jun 30 2017, 05:19 PM
FastFroggy   Thanks, yep idle mixture screws.   Jun 30 2017, 05:59 PM
stownsen914   2 full turns on the idle mixture screws sounds lik...   Jul 1 2017, 06:10 AM
FastFroggy   I am initially working for initial throttle tip in...   Jul 1 2017, 04:48 PM
McMark   You should post the entirety of your setup. Engin...   Jul 4 2017, 08:21 PM
john77   4 sounds like a lot just to get it stumbling off t...   Jul 7 2017, 04:53 PM
FastFroggy   Thanks for all your input. Sorry, got delayed by a...   Aug 8 2017, 07:30 PM
ThePaintedMan   36 venturis in 44s for a 1.7 liter is HUGE. I...   Aug 9 2017, 06:30 AM
rhodyguy   I think george nailed it. The venturies are VERY l...   Aug 9 2017, 08:47 AM
Jetsetsurfshop   I think I know something here...lets see if I can ...   Aug 9 2017, 02:26 PM
FastFroggy   I should have been clearer that engine block is a ...   Aug 9 2017, 06:17 PM
McMark   You're going to have a really hard time withou...   Aug 12 2017, 08:13 AM
ThePaintedMan   :worship: Boom. Mic drop. Mark knows his stuff. It...   Aug 12 2017, 04:44 PM
FastFroggy   Look I bought the car with this set up and I am tr...   Aug 13 2017, 09:17 PM
stugray   [b]If it continues I'm out. I [b]was going...   Aug 15 2017, 10:04 AM
McMark   I didn't intent for you to feel beat on. I...   Aug 14 2017, 07:26 AM
FastFroggy   Thank you for your note. Again, I really apprecia...   Aug 14 2017, 10:47 AM
rhodyguy   Forget that 6.8k rpm number for your calculations....   Aug 14 2017, 11:19 AM
michael7810   The redline on my 4 cyl car is 5.6K. Can you reall...   Aug 14 2017, 01:46 PM
Jetsetsurfshop   The redline on my 4 cyl car is 5.6K. Can you real...   Aug 14 2017, 03:46 PM
euro911   Quit brow-beating the new guys, Mark :poke: :l...   Aug 14 2017, 04:31 PM
FastFroggy   :blink: I understand the consensus ( for overall ...   Aug 14 2017, 05:13 PM
Racer Chris   Keep the 44s. Don't expect good performance be...   Aug 15 2017, 07:05 AM
Racer Chris   Depending on your specific engine build you may ev...   Aug 15 2017, 07:17 AM
- Lo-Fi Version Time is now: 4th July 2025 - 03:43 AM
