oil change, need advise |
Dave97 |
Aug 10 2017, 08:06 AM
Newbie Group: Members Posts: 44 Joined: 25-July 17 From: Calif Member No.: 21,285 Region Association: None |
new to me 914 needs an oil change. car has "tuna" can sump, remote oil filter and cooler. cooler is located in back, mounted high under under trunk.
estimate of how much oil it holds? does the oil cooler drain back to the engine? with engine warm, where should oil be on dip stick? thanks Dave |
Dave97 |
Aug 10 2017, 09:22 AM
With the cooler mounted high, does the oil drain back when the engine is shut off? Does that change the dip stick reading? Upon startup, does it need to pressurize the system?
Lo-Fi Version | Time is now: 9th June 2024 - 09:04 PM |
