| porschetub |
Aug 12 2017, 04:25 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,145 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Had one fail in my 914,there seems to be a common failure point around the top casing that fits to the main assembly,this design is the the same for early Golf,944,T 1 and T2 aircooled Audi and I would expect many other in "the family''.
The return spring mounts via a tab on the spring into a hole in the top assembly,repeated use causes the area to crack. The result is that the green plastic centre section loses tension and pops upward which in turn causes the metal wiper plate inside the switch to make a poor contact as it moves through its arc. The end result of this poor contact is complete or partial failure,the crack in the housing shown in picture 2 is from my early 944 switch this was enough to stop injector pulse due to insuffient power to my ECU. I pulled a known bad switch from another VW I had and found no crack in the housing but the contacts inside were all gummed up as the grease had gone bad and the contact pins were oxidized,cleaned it and it worked in the 944 till the correct replacement arrived. |
| nditiz1 |
Aug 12 2017, 09:11 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,272 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region
Note that the genuine porsche one from PP does not include a 20% increase and 3-5 week ship from Germany. PP should really update the listing that they don't have the part and have to order it from Germany. I cancelled my order of that one for that reason.
| porschetub |
Aug 12 2017, 11:52 PM
Note that the genuine porsche one from PP does not include a 20% increase and 3-5 week ship from Germany. PP should really update the listing that they don't have the part and have to order it from Germany. I cancelled my order of that one for that reason. Sorry my bad,too many people buying the $8 part lol,pretty rude how PP do that considering they are moving boxes of stuff from Porsche on a regular basis. bbrock that discussion never really came to a final outcome on the genuine switch,some having issues with the cheap ones however. |
porschetub Ignition switches Aug 12 2017, 04:25 PM
914_teener Yep....
Very common. My switch failed when it got... Aug 12 2017, 04:38 PM
porschetub
Yep....
Very common. My switch failed when it go... Aug 12 2017, 05:00 PM
porschetub Part 2 of my rant :rotfl: ,you can tell I had not... Aug 12 2017, 04:58 PM
ndfrigi same what happened with my previous 75.
Aug 12 2017, 05:25 PM
nditiz1 So what is the fix?? I just bought a supposed ... Aug 12 2017, 05:46 PM
porschetub Hi Noel,that switch is a standard failure ,I reall... Aug 12 2017, 05:50 PM
jim_hoyland Is it true that a remote hot-start relay takes the... Aug 12 2017, 05:59 PM
Mark Henry
Is it true that a remote hot-start relay takes th... Aug 12 2017, 07:15 PM
porschetub
Is it true that a remote hot-start relay takes t... Aug 12 2017, 08:18 PM
Spoke
Is it true that a remote hot-start relay takes th... Aug 12 2017, 07:23 PM
r_towle Thankfully, it's the same switch on mid to lat... Aug 12 2017, 06:06 PM
porschetub
Thankfully, it's the same switch on mid to la... Aug 12 2017, 08:46 PM
bbrock
That's why I asked if anyone had used the gen... Aug 12 2017, 09:11 PM
jim_hoyland Thanks ! That is a terrific explanation. Can y... Aug 12 2017, 07:53 PM
Spoke
Can you elaborate on the use/need of a suppressio... Aug 13 2017, 07:57 AM
r_towle Pretty sure they are all made in the same factory.... Aug 13 2017, 12:33 AM
Mark Henry
Pretty sure they are all made in the same factory... Aug 13 2017, 07:22 AM
McMark As 3D printing has evolved I've wondered if so... Aug 13 2017, 08:24 AM
Mark Henry
As 3D printing has evolved I've wondered if s... Aug 13 2017, 11:30 AM
rhodyguy Anyone with first hand experience on the German on... Aug 13 2017, 11:37 AM
Anyone with first hand experience on the German o... Aug 13 2017, 12:10 PM
Porschef
Anyone with first hand experience on the German o... Aug 13 2017, 01:12 PM
porschetub
[quote name='rhodyguy' post='2516510' date='Aug 1... Aug 13 2017, 06:23 PM
Mark Henry
[quote name='rhodyguy' post='2516510' date='Aug ... Aug 13 2017, 06:48 PM
barefoot
[quote name='rhodyguy' post='2516510' date='Aug 1... Aug 14 2017, 11:35 AM
Jeff Bowlsby Porsche OEM only, the cheap knockoffs do not last.... Aug 13 2017, 04:18 PM
porschetub Yea have seen that metal switch Mark ,got to be be... Aug 13 2017, 06:08 PM
nditiz1 I did call the local dealership, but the guy on th... Aug 13 2017, 06:16 PM
I did call the local dealership, but the guy on t... Aug 13 2017, 06:23 PM
Mark Henry 111-905-865 L
Type one 1974 to 1998, I assume the... Aug 13 2017, 06:57 PM
Porschef I don't know what the part numbers are, all I ... Aug 14 2017, 03:50 AM
saigon71 Thanks for the info on the "Genuine Porsche... Aug 14 2017, 05:39 AM
nditiz1 Does anyone know if the part number above will wor... Aug 14 2017, 06:02 AM
michael7810
Does anyone know if the part number above will wo... Aug 14 2017, 07:16 AM
nditiz1 Coming from aircooled beetles I am wondering how t... Aug 14 2017, 08:22 AM![]() ![]() |
Lo-Fi Version | Time is now: 29th July 2026 - 08:58 PM |
