> electrical woes
Mike1981
post Aug 19 2017, 12:03 PM
Hello everyone
Hoping to get some electrical help on my 72
It has a V8 in it but will not pass any power
No buzzing of the fuelpump
No dash lights
No radio
no horn
nothing
I pulled the ignition switch and tested it
It was open until I turned the key and ohmed to almost 0 ohms
When I released it open circuit
Checked all wires in harness good
Ohmed out every fuse in the panel below dash as well as a few in the rear of the car.
Checked the ground strap (now a battery Cable)
At first I was not getting continuity between the tranny bolt and the body
Cleaned up the connection to the tranny as well as to the body ohms out to 2 ohms
Checked the battery 12.5 volts
Ohmed from neg terminal to chassis ground ohmed to 2-3 ohms
It was running fine yesterday until i turned on the headlights while staring it
then it died and I havent been able to get it to crank
Any help would be appreciated
thanks
MIke
Mike Bellis
post Aug 19 2017, 04:29 PM
Resident Electrician
Sounds like 2 of the 4 wires connected to the positive battery terminal are disconnected. 2 go to the alternator circuit and 2 go to the fuse panel/ignition switch.
- Lo-Fi Version Time is now: 31st July 2025 - 01:30 AM
