| Beebo Kanelle |
Aug 20 2017, 04:27 PM
Member ![]() ![]() Group: Members Posts: 248 Joined: 22-November 12 From: Houston, Texas Member No.: 15,177 Region Association: Southwest Region
The camshaft is 180 degrees out so that #3 is now in the #1 firing order.
Problem is that the distributor lobes are 36 degrees off. There is insufficient room to rotate the distributor and properly set the dwell My first thought is to pull the distributor and rotate it 180 degrees so that it can be set up with proper dwell,etc. I am afraid the distributor drive itself has an offset and will not allow me to do this... I think its wise to ask the experts Is this possible? Solutions? Your thoughts? thanks in advance. |
| Beebo Kanelle |
Aug 20 2017, 07:25 PM
thanks for the help.
The wires were swapped when I got the engine (that was the first hint). But the giganto vacuum can will not allow the distributor to rotate enough to bring it within specs. Thanks again. |
Beebo Kanelle Camshaft is 180 degrees out. Aug 20 2017, 04:27 PM
Spoke I had the same issue when getting a new-to-me engi... Aug 20 2017, 04:43 PM
Mark Henry
I had the same issue when getting a new-to-me eng... Aug 20 2017, 05:36 PM
Vacca Rabite The easiest solution when you are 180 out is to ro... Aug 20 2017, 05:44 PM
Beebo Kanelle what's the best way to pull the dizzy gear? m... Aug 20 2017, 06:29 PM
Beebo Kanelle and regarding the shim at the bottom, how do I pre... Aug 20 2017, 06:33 PM
Vacca Rabite Use a magnet. The shim will probably not come off... Aug 20 2017, 06:41 PM
Perry Kiehl I found an old drumstick that I cut the tip off wo... Aug 20 2017, 08:02 PM![]() ![]() |
Lo-Fi Version | Time is now: 22nd November 2026 - 10:47 PM |
