Quickie 2.0 Rebuild |
McMark |
Oct 17 2016, 05:21 PM
One of my winter tasks is to build a stock 2.0 with my MicroSquirt fuel injection that I can install in my car and get it dyno tuned. That's been the missing piece of my MicroSquirt setup for the last few years.
Since there isn't much demand for a stock 2.0, I just plan on doing the minimum to build a solid motor. I plan on having the valves reground, cylinder surfaces machined and reringing the pistons. Regrinding the cam and rebuilding the rods and all new bearings as well. This should give me a motor that will last through the testing, and be worth something when I'm done to pass on to a new owner at a nice price. This thread does not represent my standard procedures for rebuilding engines. This is a special case and special circumstances. For those of you on a budget, but looking to refresh their motor should appreciate this writeup. Starting off with a core engine. The previous owner mentioned this engine had a 'knock', so I'll be on the lookout for what might have caused that. This is a 'GC' code engine with air injection ports in the heads. Attached image(s) |
McMark |
Oct 17 2016, 05:37 PM
And finally, it appears the cam was beginning to go flat. It was a reground stock cam (as far as I can tell), but this lobe has a very rough wear pattern on the nose and the associated lifters were looking pretty rough.
Attached image(s) |
rgalla9146 |
Aug 23 2017, 02:07 PM
Advanced Member Group: Members Posts: 4,563 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
And finally, it appears the cam was beginning to go flat. It was a reground stock cam (as far as I can tell), but this lobe has a very rough wear pattern on the nose and the associated lifters were looking pretty rough. can you believe this ?.....VERY heavy wear. Attached image(s) |
Dave_Darling |
Aug 23 2017, 11:01 PM
can you believe this ?.....VERY heavy wear. That is strange; it looks like part of the typical wear? I'm more used to seeing double-arch patterns with a flat-bottomed notch in the nose of the cam. That one looks like a single-arch pattern and the notch has an angled bottom. Am I remembering wrong, or is this odd wear? --DD |
rgalla9146 |
Aug 24 2017, 08:16 AM
can you believe this ?.....VERY heavy wear. That is strange; it looks like part of the typical wear? I'm more used to seeing double-arch patterns with a flat-bottomed notch in the nose of the cam. That one looks like a single-arch pattern and the notch has an angled bottom. Am I remembering wrong, or is this odd wear? --DD Guys I wish I could offer more info on how this got so bad. I can't Dave I can't explain the pattern either. Valves adjuster to near coil bind ? .... no oil pump drive ? The cam came to me in a box of parts along with a car... long ago. |
worn |
Aug 24 2017, 06:51 PM
can't remember Group: Members Posts: 3,156 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
can you believe this ?.....VERY heavy wear. That is strange; it looks like part of the typical wear? I'm more used to seeing double-arch patterns with a flat-bottomed notch in the nose of the cam. That one looks like a single-arch pattern and the notch has an angled bottom. Am I remembering wrong, or is this odd wear? --DD Guys I wish I could offer more info on how this got so bad. I can't Dave I can't explain the pattern either. Valves adjuster to near coil bind ? .... no oil pump drive ? The cam came to me in a box of parts along with a car... long ago. The tap pet has worn hollow so that a ball would stand in it end on. The dished tap pet is wearing evenly across its width, scooping away at the edges at the lobe. I am guessing that the tap pet was still rotating in its bore, which was probably pretty durn worn. Worn. |
Lo-Fi Version | Time is now: 1st June 2024 - 10:30 PM |
