> how to get out rusted rocker panel screws, I tried everything I know...
914 RZ-1
post Aug 27 2017, 08:01 PM
Porsche Padawan
I had to take off my rocker panels. The screws on the passenger side were impossible to screw off. I tried: liquid wrench, screwdriver, screwdriver with wrench, screwdriver with impact wrench (stripped slot on heads), vise grips, bolt removers (with impact wrench), hammer (tapped screws to see if I could loosen the rust), screw extractor (broke 2 drill bits and 2 extractors) and torch. Finally gave up and used a cut-off wheel to cut the heads off.
There are bolt threads sticking out of the holes. I have sprayed them with more Liquid Wrench. Any ideas on how to remove these? I'd like to put screws back in the same holes. I got hex head bolts instead of those infernal cheeseheads.
pete000
post Aug 27 2017, 08:09 PM
QUOTE(914 RZ-1 @ Aug 27 2017, 06:01 PM) *
Heat them up till they are glowing red and use vice grips. If no luck you will have to drill it out.
914 RZ-1
post Aug 27 2017, 08:30 PM
Porsche Padawan
[/quote]
Do I put the vice grips on them while they are still glowing red?
I'm also concerned about catching the car on fire! I'm thinking the undercoating might catch. Am I wrong?
- Lo-Fi Version Time is now: 6th July 2025 - 10:34 PM
